Networks New laptop ethernet not working
Discussion in 'Tech Support' started by bagman, 18 Jan 2013.
  1. bagman
    bagman Well-Known Member
    18 Apr 2009
    I need some help with my new laptop.
    It is a sony vaio s13p. The wireless works fine but it doesn't recognise when a ethernet cable is plugged into it.
    I looked on the sony website and there are no drivers for the ethernet port. So what do you guys think is the problem?
  2. Addie
    Addie Member
    9 Jan 2009
    You could try the chipset drivers, I'm going to assume you have tested this ethernet cable in your PC (or other device). Also are there any issues in device manager, it would be listed under network adapters? You could also try and reset the BIOS. It really should be working out of the box, if it is not it would be suggesting there is an issue with the port so you might want to contact those that you purchased the laptop from.
  3. goldstar0011
    goldstar0011 Well-Known Member
    2 Sep 2007
    Was it working before and now stopped?
    If not is it enabled in BIOS?
  4. bagman
    18 Apr 2009
    The ethernet cable is fine (using it now), and no I just got my laptop yesterday.
    I will check the bios now.
  5. bagman
    18 Apr 2009
    Bios settings were fine.
  6. goldstar0011
    2 Sep 2007
    When you plug cable in (both ends) do the lights come on?
    Has it been disabled in Device Manger?
  7. bagman
    18 Apr 2009
    Everything in the device manager is fine, but there is a warning sign next to the USB-IF xHCI USB Host Controller.
    As for the ethernet lights there are none on my new laptop and none on the wall where the net comes from. But on my old laptop there are and they are lighting up.
  8. lancer778544
    lancer778544 isnt really an ultramodder...
    5 Jan 2011
    What model is the network adapter? I'll see if I can find drivers from the manufacturer's site.
  9. goldstar0011
    2 Sep 2007
    Can you get a screenshot of the network adapter in device manager? Just for piece of mind
    The port should have lights on it when connected.
    Can you try plugging in direct into the router, could be a wall socket issue
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    that's a usb 3 port isn't it, I wonder if they have tied in the Ethernet via usb on the motherboard
  11. jaydeee
    jaydeee New Member
    25 Apr 2010
    do you have sony network manager? their may be some settings there that you have to check. good luck.
  12. bagman
    18 Apr 2009
    I have sent the laptop back now as it had developed another problem. It would only charge to 80%.
