News New Li-Ion tech drops fire risk
Discussion in 'Article Discussion' started by CardJoe, 12 Aug 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Sounds good, but one of the big problems with batteries is weight (or at least mass per unit charge capacity). This tech will just add weight at the end of the day, which might be worse for the more portable devices such as smart phones. When was the last time one of those caught fire anyway?
  3. Gareth Halfacree
    4 Dec 2007
  4. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    If they can get 90% after 1000 charges then it may well be viable.
    Question, would leaving the laptop plugged in most of the time affect the way these new batteries behave?
  5. Enak
    Enak Also known as Kane
    23 Jul 2002
    Being a chemical fire Lithium batteries burn under water... The real point to these batteries is that they are less harmful to the environment. Most modern lithium batteries are unlikely to go up in flames anyway but when you concentrate that much energy in such a small space their is always the risk of fire.
  6. sear
    sear What's a Dremel?
    2 Aug 2010
    I like how in the world of business, it's better to set a few people on fire than it is to fall behind the performance curve. Good stuff.
  7. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Actually I think it's more of a case of cutting corners to save costs enough to *just* avoid setting people on fire. Obviously a fair few companies just go all out - maybe their CEOs are pyromaniacs? I'm looking at you Jobbs.
  8. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    Lets just keep spending money on things that are less efficient so that we feel warm and fuzzy inside and then wonder why our GDP is tanking...
Tags: Add Tags
