Motherboards New Mobo Combo
Discussion in 'Hardware' started by slackda, 11 Aug 2011.
  1. slackda
    slackda Is aiming for a Headshot!
    23 Aug 2010
    Im thinking of Upgrading whilst i can still get a decent price for my existing Gear on Ebay.
    Thinking of going Intel 1155, but want to get the Form Factor down to MATX, as I want to get a smaller case.
    Looking at Getting somethign that has USB support and Sata 6Gb, ideally 4 Ram Slots, so that i can slowly upgrade the ram with lots of smaller sticks rather than forking out for Larger Sticks Straight away.
    Budget wise, im looking at around £100 depending on what processor i decide to put in, tempted to get an overclockable board as have tinkered with exisitng setup, but have read that H67 Chipsets can't be overclocked??
    Have seen the biostar http://www.bit-tech.net/hardware/motherboards/2011/06/21/biostar-tp67xe-b3-review/1 board review on the site and all in all it looks pretty good, but i have no experience of the relablilty of these boards...
    Any Ideas guys?
    Cheers
  2. faugusztin
    11 Aug 2008
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  4. faugusztin
    11 Aug 2008
  5. murraynt
    murraynt Modder
    6 Jun 2009
    You can get 8gb for under 40 quid, Should be loads.
  6. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I agree with the others: You'd have better luck getting a good processor, board and RAM now, especially while Memory is cheap, and then working on other components as you go along.
    Chuck a 2500K in a good board and enjoy ridiculous performance overheads while you work on a better GPU to throw in there to compliment such an overpowered processor.
  7. slackda
    23 Aug 2010
    Hadn't Really looked at Price of RAM atm was thinking of just keeping my exisitng 2GB stick and upgrade as and when i could,
  8. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    4gb is so cheap atm that it seems silly not to. Same with 8gb but not so much.
  9. slackda
    23 Aug 2010
    Oh i agree, new ram it is :D, im not sure wether its worth getting a Z68, over P67 , i doubt ill ever push the board that hard.....
  10. murraynt
    murraynt Modder
    6 Jun 2009
    A z68 board may not overclock as well, The z68 doesn't really preform any better it just has more features.
  11. slackda
    23 Aug 2010
    As Much as the ROG Board looks amazin i think im goona try and get my mits on a
    ASUS P8P67-M PRO Looks like it will do the job i need it to just fine.
    Ty for Input.
  12. Parge
    16 Jul 2010
    I'm thinking about getting the same board mate. Let me know if you find any good deals!
    Your other option by the way is the Gigabyte GA-Z68M-D2H
  13. slackda
    23 Aug 2010
    Best Price on Fleabay is £89.95 with 9.95 Delivery....Still cheaper than scan...
    the GB one is nice , but like the sideways ports on the Asus and from what i can see on spec there is no usb 3 on the GB board....not that i have any USB 3 stuff.....
  14. meandmymouth
    meandmymouth Modder
    15 Sep 2009
  15. Parge
    16 Jul 2010
  16. slackda
    23 Aug 2010
    oh don;t get me wrong i love the board, but having that means no SSD and no new PSU :(
  17. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    I'll give you my 2p then on the sound. It is far better than standard integrated and sounds better than my old x-fi discrete card, which was very surprising at first but most welcome.
    I went for this over the MSI GD53 because I knew how good the sound was from the Formula IV I had a little while ago (and I was looking to go smaller anyway).
  18. slackda
    23 Aug 2010
  19. slackda
    23 Aug 2010
    Thinking about this some more and the possible impact of Bulldozer on the whole thing.... do i wait 6-8 weeks and see if the New AMD's are up to scratch or hope that the New AMD's cause a Intel Price Drop??, Any idea when the newer 1155 chipsets (7X Range) are due for release?
