Motherboards New MOBO powers on but screen stays dark.
Discussion in 'Hardware' started by sad panda, 26 Sep 2009.
  1. sad panda
    sad panda What's a Dremel?
    9 Jan 2009
    Following the advice on this thread. I got a new Jetway MOBO and plugged two different power supplies into it, but nothing appears on the screen when I power it on. The new MOBO uses an 8 pin CPU connector, but I only have a 4 pin. According to the internets, this should still work if I don't use to much power.
    All I can see is an led marked pp_led3 lighting up. I don't know what that means.
    Here are my components I'm using:
    AMD Athlon 64 X2 4400+
    DDR2 800 Ram
    Jetway Motherboard
    pls help.
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    you're using the onboard video? HDMI or VGA? is there a jumper you have to change to swap from one to the other?
  3. sad panda
    9 Jan 2009
    As far as I can tell No. I've tried both HDMI and VGA w/o luck.
    However, following a troubleshooting guide online, I unplugged all the ram and tried booting it bare: same result with ram and without - led3 is lit. I tried a stick of ram from another comp and got the same result. Either I really do need 8 pin power for the MOBO (the guide seems to indicate I don't need any at all unless I got a lot of stuff plugged in) or the MOBO is DOA.
  4. sad panda
    9 Jan 2009
    I tried my friends PSU with an 8-pin ATX connector. No luck: pp_led3 is lit - no output to screen.
    Should I go ahead and RMA this board?
  5. sad panda
    9 Jan 2009
    I tried an external card. The screen remains dark but now the top half flickers sporadically.
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    sounds like something is fubar'd
  7. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Just a couple quick things.
    Have you tried a cmos clear?
    It is the onboard graphics you are using yes?
    Are the power wires etc from the case correctly plugged into the correct pins on the motherboad as will be shown in your motherboards manual?
    What noises do you hear when you turn the system on, are the fans spinning etc?
  8. notatoad
    25 Jun 2004
    is your screen okay?
  9. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Do you have a BIOS post code?
