Displays New monitor time.
Discussion in 'Hardware' started by eeevan, 25 Oct 2008.
  1. eeevan
    eeevan Dremel Master
    21 Oct 2007
    So, the time has come;
    monitor time.
    yeahhh..
    Just thought I'd look for a couple of opinions before I start my search.
    My requirements are as follows:
    -It needs to be fast enough not to ghost.
    -The colours need to be as accurate as possible. (So I don't think TN is an option).
    -1900x1200 or 1920x1200 (so 24"-26")
    I know, I know. That's what everyone wants right- the holy grail of monitors.
    In terms of budget, I'll say around $1500-$2000 CAD. Less is better, but going over is an option.
    -e
  2. alecamused
    alecamused Minimodder
    22 Apr 2008
    Eizo FlexScan S2431WH or HD2441W
    both within your budget and both are great screens witout - to my eye - noticable ghosting
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i haven't seen ghosting for years, its really not an issue anymore.
    Cant help but think a looking at Dell's 30in could be an option, not sure on price....
    NEC are making decent panels, but Eizo for the uber priced top quality cheesecake of monitors!
  4. GoodBytes
    20 Jan 2007
    The question is finding a store/online store that sells Eizo monitor in Canada.
  5. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Define 'accurate as possible'?
  6. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    get a new samsung seriers.. there amazing monitors, they get top reviews! they have somthing like 20,000 contrast ratio as well! with 2ms!
  7. eeevan
    21 Oct 2007
  8. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Get either Dell's or HP's 24-inch monitor. Both brands are excellent, and should meet all your requirements very easily. Of course, if you're serious about that budget, you could afford either brand's 30-inch offerings, which would be fairly magnificent.
  9. Otis1337
    28 Nov 2007
    that sir, is a fail monitor.... Response Time = 12ms jesus thats bad! also the contrast ratio isnt nothing to bost about. 1000:1 for that sorta money its shame full!@!@!@!
    iv never liked dell screens... specs are horrable!
  10. Burnout21
    9 Sep 2005
    You sir know nothing, the response is fine (sub 16ms) and can you personally see my than 1000 grades of grey? Be honest now. The dell 30in is a great screen and alot of pro's use them.
  11. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Maybe the NEC LCD2490? I don't know how much it costs in Canada though [$1000 US, about], or how much it ghosts [if at all].
  12. crazybob
    21 Oct 2004
    Actually, it's a very not-fail monitor. 12ms is brilliant. Sure, there are lots of monitors out there with 2ms response, but they have astonishingly bad color reproduction. In fact, pretty much anything below 8ms either uses a lower-quality type of panel or a 6-bit panel which isn't even capable of displaying full 24-bit color. 12ms will not cause any ghosting, but will give you very good color reproduction.
  13. Guest-16
    Guest-16 Guest
    Yup. I spent years on a 16ms 17" monitor and it was fine.
    I can't remember what panel the 30" 07 Dell uses though.
  14. eeevan
    21 Oct 2007
    Pretty sure the 3007hc is rockin' S-IPS.
