New Pc :0 what shall i get?
Discussion in 'Hardware' started by webbyman, 9 Dec 2004.
  1. webbyman
    webbyman Hax.
    7 Oct 2004
    :worried:
    im building a new pc for/maybe just after christmas im still stuck on the main factor of to go with the new nforce 4 + pci-e boards or just stick with agp :sigh:
    currently i have 2 ideas of what i would get :dremel:
    setup 1)
    - AMD Athlon 64 3000+/or 3200+ is it worth the extra £30? Socket 939 £100
    - nforce3+? ultra? via? mobo (with agp) £80
    - Seagate Barracuda 7200.7 NCQ 80GB SATA150 7200rpm 8MB £45
    - case and 400w psu £50
    - Radeon 9800Pro 128MB/or 256mb? as i wont be upgrading for years (AGP)£115
    - dual channel 2x256mb? pc3200? DDR ram
    £75
    total = around £465 (im ment to spend around £400 and pay extra for anything above )
    *** feel free to suggest any changes or ideas on memory, cpu, mobo ****
    setup 2)
    -nforce 4? motherboard (pci-e)
    £90
    -radeon x600pro? geforce 6600gt or something?
    £70-110
    £75
    total = around £455+
    what do you think? im finding it hard to choose between going with the 'newer ' PCI-E and the good old AGP?
    i have exculded the cd drives floppy drives extras other than the bare pc... i will be using my dads drives to set up my pc and then just keep the cd/dvd drive untill i can afford my own little extras
    :hehe:
    and would it be worth waiting untill january for nice price drops and slightly better products out?
    this new threads proberly kinda long :hehe: sorry...
  2. v0id
    v0id What's a Dremel?
    2 Mar 2002
    on the first setup, if you go nforce3, a hard drive with NCQ will not help you at all...
    I would go nforce3 and save the money, then upgrade when the hardware can actually benefit from nforce4... as it stands right now, if you build a pretty much identical system with nforce3 and nforce4, you will notice very little difference in speed, performance, or anything else... Esspecially with only a x600 or 6600GT... The hardware just isn't utilizing the new PCI-E speeds or SATA II technology yet. NCQ would be nice, but you really wont see too much of a difference unless you are running a server and doing querys 24/7... My advice, stick with nforce3 / AGP and save yourself a few extra dollars with the same performance...
  3. webbyman
    webbyman Hax.
    7 Oct 2004
    well i just though i might as well choose the seagate NCQ hdd as they are same price exactly the same spec except the newer version of it supports NCQ, i might aswell get the newer version at the same price?
    what kinda spec hardware would i need to use the pci-e benifit?
    ( i might spend and i might spend about £110 on pci-e card )
    and would there be so little performace difference that it would be hard to measure?
    :dremel:
  4. barry_n
    barry_n What's a Dremel?
    24 Aug 2004
    id go for nf4 and the 6600gt, that way u can SLI the 6600gt in futur if u find the games are getting too much for ure gfx card :D for that reason alone id buy the nf4 setup, i really hate the depreciation rate of gfx cards throwing away old ones just hurt, this way its effectively just upgrading :D
  5. Carbon
    Carbon Banned
    8 Jan 2003
    I tell you what.... why dont you search through the 10thousand other "what pc" threads to see what everyone else is getting.
  6. webbyman
    webbyman Hax.
    7 Oct 2004
    :hehe: because the other what pc threads will be older and unaccurate to the time, price... not alone about what peoples new rigs will be e.g (INTEL) , and for a start nforce4 isnt even properly out yet :rolleyes: >?
    and barry i see what you are getting at but, i will proberly end up keeping the gfx card im going to get for a long long time :hehe: im not amasingly bothered about top graphics. i though i should get a 9800pro or something along that line as they are ment to be great value for money, i will have a decent graphics card for now and as it depreciates i wont be upgrading for a few years lol so is it realy worth getting nforce4 ?
  7. barry_n
    24 Aug 2004
    in that case no, because the sli nf4 mobo's start at about £150.
    i still think P4 is the way to go atm.
  8. webbyman
    webbyman Hax.
    7 Oct 2004
    lol :hehe: dont even get started about processors took me longenough to even decide that :eek:
    and i have seen nforce4 mobos at about 1 or 2 about £90+
    for instance gigabyte nforce4 board
  9. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    Innacurate? There was just one around a few days ago.. son, I know new hardware comes fast but 3 days aren't going to make an impact on what you should buy.
    PS: My advice is to research stuff for yourself and put together a PC that is based on YOUR needs and wants, not someone else's. Just like the fish saying, I can give you a pc layout and satisfy your needs for a while, or I can point you in the right direction and satisfy you for life.
  10. webbyman
    webbyman Hax.
    7 Oct 2004
    i dont do an amasing amount of gaming but it would proberly be a good idea to go for a gfx card thats going to last isnt it? i dought i will want to replace it for a few years lol.
    i will be using this pc for just about everything, except engineering cad and video edditing. i will play games quite a bit and be in the everyday desktop loads for just word processing, browsing the web, and talking to freinds.
    i would like this setup to last me a few years, and i will proberly build on it a little , but not much.
    is it worth paying £30 for 200mhz?
    :worried: proberly not i guess, and in my eyes im guessing im not realy going to need pci-e and there wont be only very minour performance changes in nforce 3 ultra and nforce4 and agp will be round for quite a while yet?
