Build Advice New PC Build help :)
Discussion in 'Hardware' started by Artanix, 31 Mar 2010.
  1. Artanix
    Artanix Minimodder
    10 Sep 2006
    Hey guys,
    I'll keep it short, but I've not been keeping on top of hardware at the moment, so I'm a bit in the dark, here's the lovely template:
    Budget: £500 (or around, if you can justify it, I'll go up to £700)
    Main uses of intended build: Gaming
    Parts required: Whole new tower (minus case)
    Previous build information (list details of parts): Old build is going to the g/f ;) but I'm keeping my case, Antec P182.
    Monitor resolution: 1680x1050 (will increase once I have the cash for a nice screen :))
    Storage requirements: 750GB +
    will you be overclocking: not really
    Extra information about desired system: Completely open to suggestions, I've checked the build on the old PC Buyers guide from last month, just looking to see if anything has changed massively in a month.
    Cheers guys :)
  2. Artanix
    Artanix Minimodder
    10 Sep 2006
    So here's what I've come up with:
    CPU: Intel Core i3-530 2.93Ghz
    Motherboard:Gigabyte H55-UD3H
    GPU:ATI HD5770 1gb
    Memory:Corsair DDR3 PC3-10666 4gb
    PSU:450W Corsair CMPSU-450HXUK *modular*
    Drive: Lite-on drive
    HDD: Samsung 750GB (F1/F3??)
    Ran these into Scan, Dabs and OCUK. Scan came out best at £543.75, including the modular PSU instead of the standard 450w that corsair do. Would this be too much for what I want? and if anybody knows any other good PC sites that can beat that price, would be good.
  3. Baz
    Baz I work for Corsair
    13 Jan 2005
    Build looks spot on tbh - you've obviously done your homework. Get the F3 rather than the F1 as it's noticeably faster but other than that, nice build for £500
  4. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    £500 = dual core i3/5770
    £700 = quad core i5/5770
    If gaming's what you do, though games are moving towards quad-core coding, in general duals are sufficient. If duals are OK, your build looks spot on. The HX450W is excellent and good for a tidy build - I highly recommend it - and you need a cooler? Something like the Gelid Tranquillo will be just perfect.
  5. rollo
    rollo Modder
    16 May 2008
    retail cooler if not overclocking isnt that poor
  6. PureSilver
    16 Dec 2008
    Oop, sorry. If OP isn't planning on overclocking, I'm not sure that i3 530 will be good enough for modern games; sure you don't want to consider it?
