Build Advice new pc need help and info
Discussion in 'Hardware' started by zack8464, 7 Aug 2009.
  1. zack8464
    zack8464 What's a Dremel?
    15 Feb 2008
    im thinking about buying a new "pc" what i already got is northQ flex 850, 2x500 GB hdd and 2xZotec geforce 275 amp.
    Now what i need is a new motherboard, cpu and memory.
    I have been thinking about asus rampage II extreme and a i7 920 and then im at a loss about the memory,
    the budget is about 800-1000£
    any help would be appreciated:thumb:
  2. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Forget the rampage II extreme and opt for the P6T Deluxe, nothing to be gained spending the extra cash, you could put this into memory.
    Corsairs dominator memory will serve you well if you plan on overclocking.
    Pretty much all the 6gb DDR3 1600 kits will be a good buy though.
  3. zack8464
    15 Feb 2008
    There is only 30£ difference between the bords is ther any change from board to board?
  4. zack8464
    15 Feb 2008
    Oh and yes i plan on overclocking and I have a warter cooling system for the cpu
