Cooling New Plexi Water Tank - 36 PICs =>>
Discussion in 'Hardware' started by Avner, 27 May 2004.
  1. Avner
    Avner What's a Dremel?
    19 Sep 2003
    Hi there !
    I was just finishing the water tank
    it is 5mm plexi plates
    2X 14*11
    2X 15*10
    2X 11*10
    the pump is very very very quiet , and almost all vibrations are cancelled
    also great air trap functionality
  2. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    It's quite hard to tell, but it looks like you have removed the inlet of the pump. Is this correct.
    My only concern relates to the efficient operation of the impeller.
    Normally, water would enter at the center over the center of the spinning impeller. This is then spun outwards toward the outlet. In your configuration, it looks like the water can spill out the front of the impeller rather than going to the outlet.
    This is not good.
    I would suggest a cap of somekind, covering the majority of the front of the impeller with the exception of a small opeinging in the centre. You should be able to see how big this needs to be by looking at the existing impeller housing.
    If I am mistaken, I apologise.
    Oh, and good work on the resevoir.
    looks good
    8-ball
  3. bleecher
    bleecher What's a Dremel?
    25 Apr 2004
    looks good.
    How did you seal the edges to one another and how did you seal the area under and around the screws and the copper tubes ?
    does look like the perspex is taking alot of wait on the inside wall and are the screws meaty enough ?
  4. Avner
    19 Sep 2003
    sorry to say, but this is an aquarium pump, and the inlet is like it should be...
    very strong pump by the way...
    I used special glue for it.
    I just have to put there something so it will be 90* to the ground....
  5. 8-BALL
    6 Nov 2001
    Ok, my bad.
    Good work
    8-ball
  6. xplastic
    xplastic What's a Dremel?
    18 Mar 2004
    hey! I like it.
    This looks good and saves you some room in the case too. :idea: Good idea. Does the pump throw alot of heat into the water making your temps higher or is it no big deal? Just curious...
    Good thinking tho
    take care
    X
  7. Avner
    19 Sep 2003
    Thanks for replying,
    it is really not a big deal,
    with the radiator it is even nothing :)...
    Av
  8. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    Did you use silicone to glue the plexi?
  9. Avner
    19 Sep 2003
    no any silicone
  10. glmclell
    glmclell What's a Dremel?
    8 May 2004
  11. toss
    toss What's a Dremel?
    6 Jun 2004
    Really nice dude how long did this all cost you? how much was it to make
    [:clap:]
  12. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    good job mate. mmm I reckon u should off used 3/4 or 1/2 depending which you need.
    Here
  13. Avner
    19 Sep 2003
    already glued - no need sny glue...
    thx...
    Av
  14. kipkool
    kipkool What's a Dremel?
    11 Jun 2004
    nice job :thumb:
