Build Advice New power supply
Discussion in 'Hardware' started by Viskey404, 9 Apr 2011.
  1. Viskey404
    Viskey404 What's a Dremel?
    9 Apr 2011
    Well my power supply up and died yesterday, we created a watery grave for her in the back ally, but now i have no clue what to replace her with, i had a Corsair CMPSU-400CXUK 400W Power Supply, but i think im looking for something a little more fancy this time, any good suggestions please, im all ears!
  2. Acanuck
    Acanuck What's a Dremel?
    17 Mar 2011
    Really depends on your needs and budget. You might want to take a look at this first for some ideas:
    http://www.bit-tech.net/hardware/buyers-guide/2011/03/10/pc-hardware-buyer-s-guide-march-2011/1
    The Antec TP650 seems to be the PSU of choice for midrange systems, but if you've been running on 400W, it's clearly not necessary. The earthwatts is excellent value at the moment. Check out Scan.co.uk Today Only sales frequently for some good deals.
    If you want something more fancy for the same power bracket then you could look at what Enermax has to offer. Expensive, but very nice PSUs.
    The Modu87 500W is a particularly nice one, with excellent efficiency. It comes at a cost though:
    http://www.scan.co.uk/products/500w...ld-93-eff-sli-crossfire-139mm-fan-dxxi-ready-!
    I have experience with the OCZ ModXStream 500W which received an award from CPC a while back. It may not have the efficiency or features of some others, but it often comes in at less than £50 which is a bargain for a quiet, rock solid PSU.
    I hope this helps. Let us know what sort of kit you're planning on powering.
  3. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    maybe go modular?
    whats your budget?
    I'd thoroughly recommend this http://www.scan.co.uk/products/650w...bronze-85-eff-sli-crossfire-eps-12v-135mm-fan
    just purchased one for my server i'm building
    or if your prepared to spend a bit more http://www.scan.co.uk/products/650w...bronze-85-eff-sli-crossfire-eps-12v-120mm-fan
    or http://www.scan.co.uk/products/650w...d-90-eff-sli-crossfire-20db-eps-12v-140mm-fan
    providing your budget allows I would get a modular power supply
    if not then any of these are good
    http://www.scan.co.uk/products/500w...nze-82plus-eff-sli-crossfire-eps-12v-80mm-fan
    http://www.scan.co.uk/products/520w...nze-135mm-quiet-fan-atx12v-23-eps12v-v291-psu
    http://www.scan.co.uk/products/380w...lus-bronze-82-eff-eps-12v-80mm-fan-atx12v-v23
    also a few questions to the op, how long have you had that power supply, what did you think of it, and was it particularly loud?
