Modding New Product: CoolSleeve
Discussion in 'Modding' started by modsquad, 18 Apr 2004.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I just discovered this stuff. It is PVC and comes in UV reactive blue,red,green. It is designed to prevent kinks in a H20 cooling systems tubing, but will work on any wire of the same size or smaller. It was $3 US for a 40" piece from SVC.com
    I am not sure if I am going to use the stuff in project Blue_Monday, but here is a picture.
    MS
    http://server6.uploadit.org/files/jeffrey9-coolsleeve.jpg
  2. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    That looks pretty good. Does it come in solid colours too? :dremel:
  3. rob_65
    rob_65 What's a Dremel?
    5 Apr 2004
    You can get this stuff in the UK, they're called chameleon springs.
    Yeah, they come in solid colours too!
    Here!
    HTH :)
