Hey there guys and gals!!! New to the posting in these here forums, but not new to reading and browsing this quailty site... many a time have i drooled over the galleries in these forums and articles!!!! I am about to build a water cooled PC... I already have a coolermaster stacker case (STC-101)... I am about to buy.... Asus M2N32-SLi Deluxe NF590 SLI, Socket AM2 AMD AM2 Athlon 64 4600 X2 600W FSP Sparkle Epsilon FX600-GLN SLi 2Gb Corsair TwinX XMS2, DDR2 PC5400 (677) 512Mb Point of View 7900GTX PCI-e 2 x 250 Gb Seagate ST3250624AS Barracuda 7200.10, SATA300, 7200 rpm, 16MB Cache, Creative Sound Blaster X-Fi Xtreme Music Sound Card OEM The first thing is, does anyone have any recommendations.... I am pretty set on this spec due to price/budget, but i am negtioable a little!!!! The second thing is, and this being the most important, what watercooling system should i get..... what i want is a CPU/VGA/chipset solution... i have looked at Asetek and alphacool... I have been onto dangerden's site but didnt really know what to get!!! Thus can anyone give me a hand!!!! As a third thing, what DVDwriter would you recommend???? Thanks for your time, fellow geeks!!!! Scott B - Section8
dude i will recomend alphacool as tehy do good stuff at a low price www.alphacool.de great selection of stuff there put up a list of wc parts and people will tell you what they think of your spec
just round the corner? how long? i like the conroe chips but i am an AMD fanboy... maybe thats not so good!!! thanks Scott B
Whats the price range for wc? I would put it between aqua computer and danger den myself. But I haven't looked at others much.
anything between £120 and £200... making that $225 and $376 respectively... i do like the danger den stuff but dont really know what im looking at... they do do kits tho, but again i dont know too much about the original components... thanks for the replies Scott B
my nec is pretty damn loud tho, not suitable for silence freek... i dont use it to often anyways, only for burning stuff
well im not too worried about noise as long as its not super-excessive!!!! thanks agian for the replies! Scott B
