Graphics New Radeon 5850 launch...
Discussion in 'Hardware' started by Parge, 12 Apr 2011.
  1. Kovoet
    Kovoet New Member
    26 Aug 2009
    Still not a bad price. Wish I'd known this last week
  2. Parge
    16 Jul 2010
    Wow! That is fast!
    I still think its an amazing deal. People have been very positive about its silence too. I know if I had £100 to spend on a GPU what I'd be buying.
  3. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    Damn, seems I massively underistimated the 5850. :lol:
    /Ontopic The overclocking results seem a bit dissapointing to be honest. The 5850's usually overclock like a dream. Is it purely down to locked voltages or could it possibly that these one didn't bin very well - possibly hence the re-release and low prices.
    Edit: Ninja'd by Parge, had the reply open while playing BC2, next time I will get there first!
  4. Marine-RX179
    Marine-RX179 New Member
    24 May 2010
    Damn typo lol
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    To be honest, I'd be more worried about any potentially cheaper components used to bring the price down.
  6. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    IIRC any HD5850 that didn't have voltage control clocked relatively poorly compared to ones that did have it. I *think* the original reference design models could be "unlocked" to gain access to the voltage tweak feature but ones that ran a custom PCB (and thus a different voltage regulator) were not capable of this unless otherwise stated.
  7. Domestic_ginger
    Domestic_ginger New Member
    16 Mar 2010
    Of the revision two cards the only one I know for sure that can not be voltage unlocked using trixx is the XFX egg cooler. Many of the revision two cards also used the same coolers and PCBs on 5870s so you know they can handle higher voltages and clock speeds.
    Trixx has been around on and off since about 2003; I'm not sure which versions people are trying to be honest. Sapphire states trixx does support voltage control.
  8. chris66
    chris66 Member
    10 Jan 2011
    TBH, I couldn't care less about its overclocking prowess (or lack of) - the fact is that it is a great little (well, not so little - as big as my 580, in fact..) card for the money, whichever way you look at it.
  9. xaser04
    27 Jun 2008
    The HD5850 in question is 8.5" long.
    Domestic_ginger - I didn't know that about Rev 2 cards. That is good to know though.
  10. shaunboy
    shaunboy Phenom II's are cool guys
    31 Jan 2010
    This card was on Overclockers a few weeks ago and I picked one up for £107, extremely good for the price.
  11. chris66
    chris66 Member
    10 Jan 2011
    Oh, they must have shrunk it then. the 5850 in our HTPC is 11" long (just measured it, out of curiosity) - the same as the GTX580 virtually.
  12. xaser04
    27 Jun 2008
    This one looks to be using a custom Sapphire design (most likely to keep costs down) hence the size.
    I thought reference design HD5850's were shorter than HD5870's? The HD5870 I had was 11" long.
  13. chris66
    chris66 Member
    10 Jan 2011
    Ours is the 1GB XFX HD5850 Black Edition - definately 11" long. I do recall at the time wondering why it was so long for a 'mid-range' card.
  14. Elton
    23 Jan 2009
    It wasn't a midrange card back in the day.
    Wish I would've waited a bit longer, this card is an absolute steal!
  15. trig
    trig god's little mistake
    10 Aug 2006
    yeah, marine has a tendancy to use phrases like that without really looking at who says what or taking into account that it's common to hear from people with problems whereas the people without problems tend to not post...
    really?
    wonder how occ got theirs to 1000+ on the core? using trixx no less...
  16. Telltale Boy
    3 May 2010
    I'm going to guess that they just had a particularly good card as they say this in their review:
  17. trig
    10 Aug 2006
    most definitely...but it wasn't a gold sample or anything...
    as always, you're mileage may, and most likely will, vary.
    im curious if the oc kitguru achieved was done for xfire or was that done while in single card configuration.
  18. Telltale Boy
    3 May 2010
    I think they just got luck really. I don't think that Kitguru would have got a significantly better overclock in a single card setup as Hardwareheaven got a similarly low overclock of 840Mhz.
    Source: http://www.hardwareheaven.com/revie...e-and-x58-pure-black-power-temp-noise-oc.html
  19. trig
    10 Aug 2006
    im also curious how they arrive at a stable oc? didn't see anything in either kit or hh that said how they went about it...didn't read too thoroughly though...
    regardless...at $150, even at stock, this is a great deal...at that price you have to drop down to a 768 mb 460, and even with a good oc on that card vs this card stock, it's a slightly better card.
  20. Marine-RX179
    24 May 2010
    I believe the default voltage that comes with the non-reference cards varys...some might have higher default voltage than the others, so they could achieve higher overclock.
    But if someone got a high default voltage card, they could upload their bios for other people with the same model card to flash to I guess?
