Graphics New Radeon 5850 launch...
Discussion in 'Hardware' started by Parge, 12 Apr 2011.
  1. Droih
    Droih Your too close if you can read this
    17 May 2010
    The price on this sausage is what makes it worth buying, or Sapphire just got an super sweet deal on some Cypress that other producers wanted gone and sells it now really cheap (for us atleast) and makes some buck? :D
  2. trig
    trig god's little mistake
    10 Aug 2006
    I could see that...would make sense for the large difference in oc results...
    been waiting till i can save for a 560, but this bang for buck might be enough to just do the deal...if marine's suggestion was indeed an option, that would seal the deal...
  3. shadow_boxer
    shadow_boxer Minimodder
    22 Jan 2011
    Cracking little card. Only 8.5" long, although the PCI-E power connectors are on the end. Bought for £107.99 from OcUK (inc. free next day delivery). Not tried overclocking yet, my lowly Corsair 400W PSU doesn't feel upto the task just yet! lol.
  4. Parge
    16 Jul 2010
    Your PSU should be fine for OCing mate!
  5. trig
    10 Aug 2006
    definitely...give it a go and let us know. Use trixx if you can.
  6. ssenginss
    ssenginss What's a Dremel?
    13 Sep 2009
    What am I doubtful about this card is noise level actually I know many little nastys sapphire cards and I can not tell you that I expect a good built-in quality.
    Has anyone experienced fan noise with this series ?
  7. Destructive
    Destructive What's a Dremel?
    10 Feb 2011
    I would so get one of these if my psu had enough connectors...
    Sent from my iPod touch using Tapatalk
  8. Austin
    Austin Minimodder
    16 Jul 2004
    :thumb: Regarding Crossfire; you don't need to match cards with Radeons. It used to be the more capable card would reduce itself down to match the less capable card but AFAIK modern drivers intelligently distribute the load so both cards can stay at full speed/shader count. I think nVidia SLI is generally a little better except that the cards need to be closely matched. This is all to the best of my knowledge, be sure to check before splashing the cash!
  9. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    my 5850's in crossfire run great! I cannot adjust the voltage on mine, but i can take them to 850mhz core and 1200mhz memory and they love it all day! I think i could go higher but i don't to blow them up. I cannot recommend the 5850 enough.
  10. chris66
    chris66 Minimodder
    10 Jan 2011
    ...And now you can get a 5870 for £143!
  11. Droih
    17 May 2010
