Cooling New Reservoir?
Discussion in 'Hardware' started by Lithium, 30 Mar 2004.
  1. Lithium
    Lithium super spunk
    26 Jul 2002
    Not too sure if I can spot the diffrence here between my new and old res...what do ya think? :D
  2. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    hmm
    well if u change the res your gona have to do something with the existing holes in the *mesh* but i think it looks pretty cool as it is :D why not just add the 2nd res inside the case!? then u can have more water and it would take longer to heat up :D *or something like that o_0*
  3. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    :duh: hes added his new res, the old one is the one not in use.
    'doc
  4. Lithium
    Lithium super spunk
    26 Jul 2002
    Eh...what ya on about the existing holes :confused: Na I'll just stick to the 1 res...after all the cooling can't be too bad if I have my XP 2600 running at 2.3Ghz :D
  5. P2D
    26 Mar 2004
    LOL, made myself look a prick got myself all confused :D ahh nevermind :D..if u aint gona use the old res can i have it o_0 :D pretty pretty please :thumb:
    Anyway isnt the purpose of a res to be able to refil the water easy and fast? coz i would like to see you do that hehe *if none of this makes sence, just ignore me..*
  6. Lithium
    Lithium super spunk
    26 Jul 2002
    sure...for a price, pick 1.
  7. P2D
    26 Mar 2004
    hehe, ill take the lot..how much is that worth then..?
  8. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    You are going to fill the system up a bit though Lithium??
    just looks a bit empty...nice though :thumb:
  9. slater
    slater Mummy Says Im Special
    18 Apr 2003
    looks good but needs a filler cap on top. Do you tip the case on its back to bleed or something?
  10. P2D
    26 Mar 2004
    2 hours of ICT at school=www.bit-tech.net forum reading :D booyah
  11. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    very nice res, i thought i had a buble going in mine damn dude that takes the biscuit :D
    pppsssttt might want to put a bit more water in there :)
    very nice
    morgan.
  12. Lithium
    Lithium super spunk
    26 Jul 2002
    Yeah was waiting on the bubble comments :D I will fill it up more tonight just a bit of a pain that I have to tip the rig on one side to fill the thing :sigh:
  13. kbn
    kbn What's a Dremel?
    17 Mar 2004
    Did you make or buy this? either way I want one :D
    Hope that isnt naked aluminuim in contact with your water, nasty corrosion? :eeek: :eeek: :eeek: :eeek:
    You need a fill/bleed thing on the top though.
  14. Lithium
    Lithium super spunk
    26 Jul 2002
    Nope not home made, not that talented...i don't think anyway. Purchased it from watercoolingshop.com.
    And yeah I do need a fill/bleed thingy bob on top...was thinking that as it is a pain in the @rse if I wanna fill it.
