New Rig
Discussion in 'Hardware' started by Mark, 27 Jul 2003.
  1. Mark
    Mark What's a Dremel?
    6 Jun 2002
    Well, after working 127 hours of overtime last month to save up the money, payday finally came. And ive just spent the lot on my new rig!! :rock: And what made me do it? Seeing the trailers for Half Life 2 & Doom 3!!
    P4 2.4ghz(c) @ 800fsb (Planning to o/c this to at least 3.0ghz)
    Corsair TwinX 1024 MB 4000 CAS 3
    256Mb ATI Radeon 9800 Pro DVI/TV DDR Retail
    DFI Lanparty 875I Mainboard
    80Gb Maxtor ATA-133 8mb cache
    Thermaltake Xaser III (Black with window)
    Thermaltake Xaser 480w PSU (Black)
    Just gotta order some Artic Silver Ceramique & 2 UV cathodes to light up my mainboard!!
    Damn im gonna be skint this month!!
  2. olv
    olv he's so bright
    23 Sep 2002
    Very nice setup (minus the case of course :lol: )
    Bad news for Doom III i'm afraid but i cant wait for half-life 2. i'm sure my xp2400 and geforce3 can handle it :waah: maybe u can lend me you rig when it comes out ;)
  3. Mark
    6 Jun 2002
    Thanks! Gotta try and plead with work to let my have the day of to build it now!
    How can u not like the Xaser III!:eeek: Ive come to the conclusion that me a dremel will never get on after nearly wrecking my Coolermaster 210 ATCS, so I thought id go for a pre-modded case instead.
  4. Guest-16
    Guest-16 Guest
    Xasers look like cheap ass boys toys. The kind of thing you go "eww! WTFs that??" at in a car mag but translated into a case.
    imo. :worried:
    what's the price diff between say - PC3500LL / PC3700 and PC4000? Cause cas3 4000 stuff is pretty crap and will be overclocked and rebadged PC3700 im sure.
  5. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    the xaser 3 is awsome. i got the blue one with a window and love it. i want to change the window becuase its the only thing that looks like crap on it. i will probably make a bigger blowhole on the top. BTW nice rig. you sure thats CAS 3 ram?
  6. Mister_Tad
    27 Dec 2002
    its cas 3 because its very fast so sacrifices have to be made in the timings, but its still rather nippy ram, as ddr500 tends to be
  7. Froggy
    10 Jun 2003
    hmm i run CAS 1.5
  8. Guest-16
    Guest-16 Guest
    @ ddr 500?
  9. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
    Nice rig, i'm just curios to know why you habe picked an ata drive insted of a sata one. :D
  10. Tim S
    Tim S OG
    8 Nov 2001
    I personally don't like the looks of the Xaser case, but, whatever floats your boat as they say
    /me hugs his CM201
  11. Froggy
    10 Jun 2003
    sorry about confusion with the ram. i run ddr-400 at cas 1.5. i had no idea that ddr-500 was out already.
  12. Mark
    6 Jun 2002
    I really wanted to go for a SATA drive, but if I did i wanted a 10,000rpm one, which is £120 for a 36gb. I couldnt justify spending that much at the time but I will be getting a couple of SATA's once they come down in price a bit.
  13. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    Yooo Mark,
    Errm I personally do not like the Case but it's your choice :)
    What heatsink do you plan to use with that LanParty MoBo?
    I'mm gettin the LanParty Tooo :clap: me=sucker for Cycadelic...
    Don't forget to get a blacklight for that UV Reactive goodness :)
    Does anyone know for sure if the Zalman 7000 Cu fits on the DFI LANPARTY PRO875?
    Cheers,
    Mat
  14. Mark
    6 Jun 2002
    Hi Mat,
    Sticking with the Thermaltake theme ive gone for the P4 Spark 7+ Xaser Edition. Ive read some pretty good reviews about the Spark 7. Also got me a Mitron UV on the way :clap: to lite up my mobo.
    Cheers
