Networks New router help
Discussion in 'Hardware' started by adamg64, 30 Oct 2013.
  1. adamg64
    adamg64 What's a Dremel?
    19 Jul 2010
    Hi guys, would love some advice on a new router its not something i have ever purchased before as ISP provided hardware is normally survice for what i need.
    However i have moved into a bigger house and my wifi range is terrible and slow speeds and way too many dropouts.
    Im on BT Infinty and i have it cabled for my main gaming PC but connect comsoles, phones etc.
    Mainly as i have a baby on the way and i have gone all high tech and bought a baby monitor that u can use on wifi and connect your ipad/iphone to them and monitor our new addition.
    But with wifi so poor upstairs i really need to improve this with her due to arrive in a few weeks i dont wanna go over bored but would like something with greatly improved speeds and range £100 budget.
    Hope somebody can help
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Not an easy question to answer TBH much depends on placement of your router. best to have it on the wall (center of you house) by the stairs.
    As to which router the Cisco E4200 is quite good.
    you keep the router you got from ISP and drop it into modem mode then connect the router over PORT:1 using a LAN Cable.
    Thats the skinny version :D
  3. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I'd go with the Asus RT-N66U. It's just slightly over your budget but gets rave reviews. It would replace your ISP supplied router (a Home Hub of some kind I presume) and will plug directly into the Openreach fibre modem.
  4. Andre_B
    Andre_B Minimodder
    17 May 2009
    +1 for the RT-N66U.
  5. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    If you have a android phone wifi analyzer and wonder around house
  6. adamg64
    19 Jul 2010
    thanks for the reply guys, that was one that i found some great read ups on.
    If I'm honest my router is not exactly in the greatest area of the house but i still feel i should be getting better range and strenght just need to find a good deal now.
    Don't have android malc but will have to check if apple do some similar.
  7. adamg64
    19 Jul 2010
    ordered from amazon for £99.99 good price will run some tests, good thing about amazon if im not impressed there returns are amazing :thumb:
  8. keir
    keir S p i t F i r e
    5 Oct 2003
  9. adamg64
    19 Jul 2010
    thanks for the advice guys the new router is running nicely and improved not had any dropouts and improved speeds and signal well happy!
