Graphics New Sapphire Xtream series, PCB bends !!!
Discussion in 'Hardware' started by ssenginss, 27 Apr 2011.
  1. ssenginss
    ssenginss What's a Dremel?
    13 Sep 2009
    When I first handle my new Sapphire Xtream 5850, I noticed the card is very flexible and weak.
    The cooler is mounted to PCB with only 4 screws around the GPU. Cooler cover is such weak
    that it can not support PCB mechanicaly. Eventually after I mounted the card it bended slightly
    as I expected.
    I tend to send it back.
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Why are you going to send it back?
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Unless it affects performance or breaks in half, I wouldn't bother sending it back.
  4. GeorgeStorm
    16 Dec 2008
    Most cards can bend, especially over time
    I'm confused why you are sending it back? Does it affect performance at all? If It's purely cosmetic the RMA will get refused.
  5. chris66
    chris66 Minimodder
    10 Jan 2011
    Some motherboards can look like bananas from a side view - so I am not surprised that some GPU's look the same, especially if they haven't got the full length casing attached.
  6. azrael-
    azrael- I'm special...
    18 May 2008
    I'd expect this kind of behaviour from one of their Flex series... :p
  7. ssenginss
    13 Sep 2009
    Well, I am not used to see a graphics card bended like that, I quickly though that bended
    shape would cause some problems over time as total weight is only carried by PCB.
    I checked the card and it's performance is OK. If bending is normal for some components and
    does not cause performance problems ( that is the point I do not know ) I agree that RMA is not necessary. So what is your opinion ?
  8. GeorgeStorm
    16 Dec 2008
    A pic would be helpful, to see how much it's bending.
  9. Tangster
    23 May 2009
    Get a support bracket? Not sure where to buy one, but you could make one out of some aluminium.
  10. faugusztin
    11 Aug 2008
    Bending... Yeah, that is brand new thing, my HD4850 had nothing like that :D :
    Anyway - anything longer than the PCI-E slot tends to bend, especially if we talk about cards with heavy coolers.
    For example, ever heard of pencil mod (not my picture, but you get the idea) ? :naughty:
  11. Ljs
    Ljs Modder
    4 Sep 2009
    I fail to see what the pencil mod has to do with a bending pcb?
  12. faugusztin
    11 Aug 2008
    Look at the picture. In front of the hard drives. How would you call it ? Pencil support ?
  13. Ljs
    Ljs Modder
    4 Sep 2009
    Ahaha! I see...
    I thought you meant the other pencil mod (lowering resistance to up voltages on things)!!
    Apologies. Can't believe I didn't notice the pencil... :/
  14. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I didn't either..hahaha
  15. Guest-23315
    Guest-23315 Guest
    I wouldn't be worried. My WC'd GPU is bowing an awful lot more than your card and it still runs fine after 3 years.
    You could try and move how the PCI-E power cable goes to the GPU so it pulls slightly on the connector, lifting the tail of the card, or could invest in something like this if you're really worried (I wouldn't bother)
  16. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    your graphics card is a bender...
  17. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    with the way pcbs are going for gpu, soon it will look like 2 motherboards attached to each other. i've noticed more cases recently that include card support, and of course as mentioned its not too difficult to make your own supports with alu or plexi. backplates are another option if they are available, or make your own to add some rigidness.
  18. ssenginss
    13 Sep 2009
    Reading all the replies I dediced to support tail of the graphics card with a simple wooden spacer and not to worry about it anymore.
    Thank you all. :thumb:
