A/V New soundcard and speakers to buy..
Discussion in 'Hardware' started by buje, 20 May 2010.
  1. buje
    buje New Member
    20 May 2010
    I am after a decent set of speakers. I live in a small flat and my computer plays all my music for the house.
    After reading custom pc I have decided to buy a Asus Xonar DX soundcard so basically I would like to know what speakers you think I should get.
    I am thinking of getting a decent pair of 2.1 speakers that will sounds great and play music loud, anything up to about £110. Any recommendations?
    Should I be getting some 5/7.1s with this soundcard? Although they would be hard to use and wire as the PC is in the lounge with the TV.
    The main use is playing music and playing games although with games I normally wear headphones.
    Any help is appreciated
  2. mac007
    mac007 New Member
    20 May 2010
    Can't comment on the Zonar soundcard, I'm a bit of a trusted established brand buyer - so for sound would always go with the Creative soundblaster range. I've got the Creative Sound Blaster X-Fi Platinum - Fatal1ty Champion with Logitech Z5500 setup - awesome sound. I live in the country so when it comes to volume -don't have a problem cranking it up - you might not be that lucky. It has built in codecs for DTS, Dolby Digital and is THX certified. So when it comes to value, features and quality can't go wrong with the Z5500's.
  3. Gryphon
    Gryphon New Member
    24 Apr 2009
    Sound quality wise I'd look towards the Acoustic Energy Aego Ms (my flatmates new ones do have a bit of a problem with them, but it seems thats a rare occurance, and i can promise you they sound amazing!). I dont think they'd enjoy a party, but they're pretty darn loud (there's a difference between listening loud, and party loud), very clear and feel very solid. (it help that the satellites are encased in metal).
    If you're more the partying type, the Logitech Z-2300s are more suited. The Z-5500s are a little out of you're price range (£250) and i much prefer the sound from my flatmates Aego Ms to my old 5500s.
    Admittedly both of the above sets are £10-£20 above your budget, but both are well worth the money.
  4. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    the creative gigaworks t40's are pretty nice, although they are not .1
  5. Gryphon
    Gryphon New Member
    24 Apr 2009
    I found the t40s sounded really good at low volumes, but as you turned them up the bass just disappeared, and they really started missing that sub.
  6. mrhrk01
    mrhrk01 New Member
    20 May 2010
  7. olimorgan
    olimorgan New Member
    16 May 2010
    I really like my Creative T3130s if you want 2.1s (having a sub does make a difference). They are only ~£30 but they sound amazing to me running off the onboard sound, admitedly I'm not much of an audiophile at all.
  8. bagman
    bagman Well-Known Member
    18 Apr 2009
    i can definatly recomend the Asus Xonar DX it is a excerlent card and there are no driver issues unlike the creative series
