new swifty *gasp*
Discussion in 'Hardware' started by Carbon, 9 Sep 2003.
  1. Carbon
    Carbon Banned
    8 Jan 2003
    just incase you wanted to see the NEW swifty mcx462-V its here i was going to buy the mcx462+ but now i think ill get that ... muahhaahah :brrr: :brrr:
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Well that looks dangerous.
    92mm fan too. Pretty nice. And still the stylish Swifty design we all love.
  3. Darv
    Darv Bling!!
    12 Aug 2002
    Well I personally wouldn't trust the socket lugs to hold anything that weighs a massive 650g :jawdrop:
    Would be much better if it used the mounting holes round the socket IMHO.
  4. Carbon
    Carbon Banned
    8 Jan 2003
    hmmmm.
  5. Mister_Tad
    27 Dec 2002
    neeeeeed a P4 one, that wont work with my brackety thing to use a normal MCX462 on my P4
    *sniffle*
  6. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Lol... no **** :p
  7. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I saw this and was really interested until I saw that part about the retention clip. I think Swiftech is shooting themselves in the foot with the new mounting mechanism. That's a frickin' heavy chunk of copper and aluminum. Wish they would have kept the bolt on mechanism. :(
    On a happier note, the idea of using the spring loaded screws to adjust the pressure of the heatsink on the processor is interesting. Should hopefully keep people from squashing amd cores. :duh:
  8. Darv
    Darv Bling!!
    12 Aug 2002
    It still uses the socket lugs which arent really designed for the weight.
    Plus if you tighten it up too much you'll probably rip off the lugs and your motherboard will be useless.
  9. Carbon
    Carbon Banned
    8 Jan 2003
    so was i, i was so excited that i posted before reading the whole page :D
  10. Tim S
    Tim S OG
    8 Nov 2001
    I was excited when I saw the images of it when it was posted on my own forums the other day, however on reading it, it's not too great, I'm not sticking anything that size on my socket lugs, deffo not! :eyebrow: :eeek:
  11. Carbon
    Carbon Banned
    8 Jan 2003
    neither am i so ill be buying the mcx-462+. its a shame though i really liked that untill i saw the mounting :(
  12. Mister_Tad
    27 Dec 2002
    fingers crossed that the P4 one will have a more sensbible mounting method
    it isnt like its a huge inconveneice to take teh motherboard out to put it on, and once it is on then you can take it on and off anyway without removing the motherboard
    pah
  13. Guest-16
    Guest-16 Guest
    Oh you are SERIOUSLY having a laugh now. 650g on socket lugs. That's 6 pieces of plastic! Pfff not a chance.
  14. Carbon
    Carbon Banned
    8 Jan 2003
    yep, i think swiftech are having a laugh at us. Still ive email'd them to ask why they are using the crappy lug design. i bet i get a reply like this
    "due to the design of the heat sink the 4 mounting hole method is un-useable"
  15. Krikkit
    21 Jan 2003
    Surely they could make something from some kind of Aluminum that simulated socket lugs from the 4 MoBo holes to stop the dangers of lug-ripping... Even a re-inforcing thing would do, might help in some way... Looks damn fine though; if they do a version with 4-hole mounts i think i'll have to make a purchase... :D
  16. Carbon
    Carbon Banned
    8 Jan 2003
    i think ill wait for a mounting hole version too :D
  17. Tim S
    Tim S OG
    8 Nov 2001
    well that's your designers fault then, they've clearly gone AGAINST AMD's design spec, so how can you expect people to use this poorly designed lump of metal on their beloved 50mm squared piece of silicon... is what my reply to that would be to that :)
  18. Carbon
    Carbon Banned
    8 Jan 2003
    part of the blame must fall upon AMD aswell, they've removed the 4 holes from the amd specs (or something like that its 1:40am cant think)
  19. Tim S
    Tim S OG
    8 Nov 2001
    from what i heard, they were put back in :eyebrow:
  20. Carbon
    Carbon Banned
    8 Jan 2003
    well i got a reply from Swiftech, this is the actual email
    so their you have it, damn you AMD !!! *shakes fist*
    i think ill email amd aswell :D !
