New system - which memory?
Discussion in 'Hardware' started by cpemma, 1 Jan 2008.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Present system (Sempron 2600+, Asus A7N8X-E deluxe) is now 3 years old and I'm looking for a cheap upgrade to something significantly nippier with better SATA support. Top of the shortlist
    • Gigabyte P35-DS3L (£50) - don't need Raid or XFire, has all the connectors I want and the price is right.
    • E2180 (£56.50) - hoping to get at least 3GHz.
    • AC Freezer 7 Pro (£11.95). Might stretch to a Ninja but it's an extra £15+
    • 2x1Gb Corsair XMS2-6400 kit (£36.25) - 5-5-5-12
    Question is on the memory. Is DDR2-800 overkill and is the £27 DDR2-633 cl4 a better buy? Or should I be looking at £52 DDR2-800 cl4?
    Hope is to oc to at least 3GHz on the cheap but stability is more important than speed, SOHO not gaming, probably stay with XP.
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I built a Q6600 P5K System last week for me. I Upgraded from the same system as you (except mine was an AthlonXP 2600+)
    If you overclock to FSB1333 (3.015GHz @ x9) then theoretically you should still only need the 667 RAM (333 double pumped) but if you want to go any further without dropping below a 1:1 RAM:FSB ratio, you might need the 800.
    I got the 800 set, and am really pleased with it. Once I pop on an aftermarket cooler, I might consider overclocking more, but with the stock HSF, I'll stick to 3GHz.
  3. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    If you can get a 667 kit for a decent amount less then any 800 kit(I don't really know what sites to look at in the UK for deals), go for it. With a processor of 10x multiplier, you can get up to 3.33GHz with DDR2-667.
