Not sure if this is the correct section for this post. But thought people might like a look a new themaltake MozartTx case. I suppose you could try to mod it. LInky (Warning its a bit slow) Specs Dimensions: 330 * 360 * 720mm Window Side Panel Aluminum Side Panel Color: Black / Siver Cooling: 5 *120mm Front, 5 * 120mm Rear + 1 * 80mm Motherboard: All ATX / All BTX Secondary Motherboard: Mini ITX (that's right it supports two motherboards) Drive Bays: 7" for fold out moniter, 5 * 5.25", 7 * 3.5" (int), 1 * 3.5" (ext). Front IO: E-SATA, USB 2.0 * 4, IEEE 1394 Firewire; HD-Audio Weight: Up to 17kg (unloaded) Optional Extras Media Lab VFD / Remote Kit 7" Fold Out Moniter Mini-ITX Drive Bay PSU BTX Upgrade What a Monster
It's all good, I did the same thing at first, one of my buddies pointed me in the right direction. Overall, I think it looks good for a ThermalTake case, but I still prefer the solid construction of a Lian Li.
Hey Sirkill. Thermaltake is actually using a standard Car In Dash screen for this case, they've just installed a 7" expansion port above the 5.25"s. You can find the screens through most automobile aftermarket stores, running anywhere from 500-2000USD depending on quality.
If you have patience: The TT site has it and a demo. Looks more like 1 DIN unit for a car than a PC part. John The link IS really slow.
