ok this case the Tsunami Aluminum Case Series-Black Series looks really cool to me but i cant find it anywhere heres a link http://www.thermaltake.com/xaserCase/tsunami/bna/bna.htm does any one know where to buy it
I have a feeling it's going to come with a high price tag and IT might have RIVETED bays(Totaly suck because you'll have to drill the rivets to remove the bays and that might result in case instability) Why not look into the mountainmod cubes? Even the Lian-LI PC75B would do
Riveted bays means the bay is held by a metal bolt that cannot be unscrewed by a screwdriver or a l-driver. The only way to remove the bolt is to drill right through the bolt. On the Lian-Li cases, the bays are held by screws that are easily removed by a screwdriver.
Bah, nothing new. Front looks like the Coolermaster WaveMaster, except the wave's on the other side. Besides the expansion card holder, everything else is from this case. I ought to know, since I own it. edit: the only bays riveted are the 5.25". The bottom bay slides out perpendicular to case, while the middle one slides out parallel.
