Electronics New To Electronics
Discussion in 'Modding' started by TheEclipse, 4 Jun 2007.
  1. TheEclipse
    TheEclipse What's a Dremel?
    2 Apr 2007
    Would Gas Soldering Irons be an option.
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Not realy but check out the shopping list i posted yesterday.
  3. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    There wont be any need for you to lay out a PCB for years or atleast months, it just isn't the right path to take at the beginning. With a PCB, if you make the board and solder the bits in and then discover that it dosn't work you've not only wasted the board theres a good chance you'll destroy the components trying to remove them, with a breadboard you just pull them out and put them back in the tray. If you decide you want a more permanent version of your circuit you can buy stripboard and build it that way. PCBs are only required when you have to make the circuit very small, have to deal with high frequencies or are going to be making thousands, even then it is possible to make a smaller circuit without using a board. Designing and making PCBs is not one of the first steps in electronics.
    Gas soldering irons are pretty awkward in my experience.
    Moriquendi
  4. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    The sofware is called Eagle. Its pretty good, my school uses it all the time!
  5. TheEclipse
    2 Apr 2007
    Can Anyone else reccommend me some tools i should have mentioned i also have an account with Rapid.
  6. AJB2K3
    12 Dec 2005
    Ive already done a recomendation list on the first page!
    As to rapid i cant help because i havent seen a catalog in nearly 3 years.
  7. TheEclipse
    2 Apr 2007
    What tools are essential for electronics. Don't i need like solder wire clippers etc. Rapid have a website google it.
  8. AJB2K3
    12 Dec 2005
    My maplins sudjestion.
    GT66W GCSE component pack £21.26( good first start set)
    FD32K Sliver plated plugblock pack (breadboard) £10.67
    70-4046 RR50E decision maker kit £4.99 or
    70-4034 RP03D Running microbug kit £9.99 (cool little robot that doesn't use microchips)
    Modded PC PSU (nice cheep multi output tester supply)Easy to use as bench PSU.
    FY69A 25 watt soldering set £21.26
    Keep an eye out for
    N78AR ls20 Soldering station because these often go in the sales very cheep although they only cost £31.14
    RAPID codes are red.
    Well straite off i recomend getting
    70-1258 Teach-In kit 4 and
    The magazine i mentioned 3 times and you should be ready to go
    all for the pricly sum of £50 ( man i wish this was around when i started 12 years ago.
    Oh and youll aways need some of theese Blue LEDS
    BTW your first project will need a 12v psu and some pc fans :thumb:
  9. TheEclipse
    2 Apr 2007
    why do i always need blue LEDs?
    A PC FAN.
  10. elctroJunky
    elctroJunky What's a Dremel?
    9 Jan 2006
    Because LED's are cool and blue is the coolest color ;)
    Seriously, LED's are important today, you can do a lot of stuff with them. If you're good you can even use them for short range wireless communication.
    But as we are in a PC casemodding scene here, you'll probably need them just for lighting your case.
  11. AJB2K3
    12 Dec 2005
    Everyone needs a blue led.
    the fan is needed (scavenge one prefered) to make a fume extractionsystem, very handy if the iron/solder/pcd is slighly dirty.
  12. Moondog
    Moondog What's a Dremel?
    3 Jul 2007
    A fingernail /toenail clipper is a nice addition to an electronics toolkit. You can use it to trim wires and leads after soldering. It's also a good makeshift wire stripper.
    I don't know if they're still in circulation, but Heathkit used to have good instructional books with accompanying lab kits. When I got my associates in electronics in the late 1980's, I was lucky to have instructors that worked in Heath-Zenith's training department.
  13. Butcher9_9
    Butcher9_9 What's a Dremel?
    15 Sep 2006
    go ebay for leds
    i have bought about 1500 leds off "top_speicherkarte24" and they do great deal if you want bulk (not that they are selling at the moment ) , and that includes the fact that i payed more to transfer the money into their bank than i spent on the leds (from Australia to Germany) where as its probely much cheaper it u live in Europe
    otherwise you can get some pretty good deals on 50+ leds from other people
