Modding New to this all...need help...plese help
Discussion in 'Modding' started by s7e7e7n, 10 Jul 2002.
  1. s7e7e7n
    s7e7e7n What's a Dremel?
    10 Jul 2002
    im new to all this. im buying a premoded case.. i know shame on me. but my questions is about fans and LED's. i will have a total of 3 fans and some led's. i have a 350 psu and amd xp 1600. will i need a bigger PSU or do i need something to vary the fans.. help.. i dont know what im trying to say... i dont want to fry anything so what must i do to avoid doing so.. point me in the right direction...
    thanks to all... msn messenger... s7e7e7n@hotmail.com
  2. G8way
    G8way What's a Dremel?
    24 Mar 2002
    A 350 watt PSU can handle 3 fans on high, no prob (LEDs included).
  3. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    got a 300 and got the whole computer (xp 1.47, mobo, dvd, cdrw, 4 pci, 2 hdds, 80mm cpu fan) + 2 cathode + 2 80mm fans + EL cable and everything is fine;)
  4. s7e7e7n
    10 Jul 2002
    Can anyone explain the rheobus, whats all that for or when do you use it.. or is it mainly looks
  5. linear
    linear Minimodder
    5 Oct 2001
    Welcome to the boards.
    Ah, the rheobus. Well, you probablyknow that those AMD chips run rather hot. So the reaction is to insert fans (lots of them typically) into your case, improving (we hope) airflow and temps. But at the expense of noise. If you go out and get the most hellacious fans you can find, they do move serious air. And they're loud.
    So at somepoint, some wise guy figured out that lowering the voltage to the fans would slow them down, and quiet them down, and they would still cool okay. And sometimes (gaming, ovrclocking) you need more flow, and othertimes (sleeping) you need quiet.
    So that's what a rheobus does, it lowers the voltage to the fan, and slows it down. It's just one of your alternatives that accomplish the same effect.
  6. s7e7e7n
    10 Jul 2002
    thanks.. nice to see a board that actually replies.
    anyone got some good ideas for some first timer mods.. im going to stealth the cd-rom and floppy.. posiably change a led on the floppy and cd-rom. anyone have good links for those..
  7. Tribal Dragon
    17 May 2002
    A rheobus is a fan speed controller that uses potentiometers and voltage regulators to adjust fan speed.
    edit: didn't reply fast enough:D
  8. Tribal Dragon
    17 May 2002
    just desolder the leds and replace;)
  9. s7e7e7n
    10 Jul 2002
    ohh.. one other thing how would i go about doing this.. shining some light on the subject.
    http://www.pcextreme.net/raidmax-a288-2.html
    about half way down.. where he is shining the flash light on there.. also where is some good switches.. to turn these things on and off..
  10. s7e7e7n
    10 Jul 2002
    how would i power the LED's
  11. Ubermich
    Ubermich He did it!
    21 Jun 2002
    You'd get that effect by placing LEDs in/on the edge of the plexy.
    You can power the LEDs off a 5v line from a molex (if you have 5v LEDs) w/ the proper resistor.
    Edit: Also, for your power supply question...
    "Power supply: How big a PSU do I need?
    list complied by RudyG from ttzforums
    AGP video card - 20-30W
    PCI video card - 20W
    AMD Athlon 900MHz-1.1GHz - 50W
    AMD Athlon 1.2MHz-1.4GHz - 55-65W
    Intel Pentium III 800MHz-1.26GHz - 30W
    Intel Pentium 4 1.4GHz-1.7GHz - 65W
    Intel Pentium 4 1.8GHz-2.0GHz - 75W
    Intel Celeron 700MHz-900MHz - 25W
    Intel Celeron 1.0GHz-1.1GHz - 35W
    ATX Motherboard - 30W-40W
    128MB RAM - 10W
    256MB RAM - 20W
    12X or higher IDE CD-RW Drive - 25W
    32X or higher IDE CD-ROM Drive - 20W
    10x or higher IDE DVD-ROM Drive - 20W
    SCSI CD-RW Drive - 17W
    SCSI CD-ROM Drive - 12W
    5400RPM IDE Hard Drive - 10W
    7200RPM IDE Hard Drive - 13W
    7200RPM SCSI Hard Drive - 24W
    10000RPM SCSI Hard Drive - 30W
    Floppy Drive - 5W
    Network Card - 4W
    Modem - 5W
    Sound Card - 5W
    SCSI Controller Card - 20W
    Firewire/USB Controller Card - 10W
    Case Fan - 3W
    Case Fan (w/LED) - 6W
    CPU Fan - 3W "
  12. Lazy
    Lazy Meow?
    13 Nov 2001
    first time advise eh?? Prepared to spend a lot of money
  13. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    Heh. It is an expensive habit...er....addiction...er...hobby! :D
  14. TwiSteD LoGic
    TwiSteD LoGic What's a Dremel?
    1 Nov 2001
    LoL, expensive.... For a while, you should add up all of the prices of the mods you are planning to do, and then... double it! Yes, screwing up tends to happen alot at first... you slowly begin to screw up less. That is at least my personal experience....
    Have fun
  15. Hiren
    Hiren mind control Moderator
    15 May 2002
    Yeah I found that happened to me quite a lot :lol: You think something is going to be simple and then you manage to find ways of screwing it up :p
