New toy to help things along....
Discussion in 'bit-tech Folding Team' started by GeorgeStorm, 24 May 2019.
  1. GeorgeStorm
    16 Dec 2008
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Nice :dremel:
    What sort of PPD is it giving you?
  3. GeorgeStorm
    16 Dec 2008
    Seems to vary from 200-350k according to the FAHControl program.
  4. DocJonz
    24 Apr 2009
    Which RTX do you have - I would expect PPD's of well over 1M as my GTX 1080s do nearly 1M PPD??
  5. GeorgeStorm
    16 Dec 2008
    Oh, clearly I'm doing something wrong then!
    My GTX980 in this PC is currently doing just over 100k.
    It's a 2080ti :(
    Edit:
    Clearly I need to tweak things, the 2080ti is on an ubuntu box I use for work, just installed the fah client and a recent driver. Seems to have high gpu utilisation % (90+) and clocks at full clocks not idle so not sure what I've done wrong.
    Possibly something to do with not having a passkey as I can't remember what mine was from years ago?
  6. DocJonz
    24 Apr 2009
    Definitely something odd there. Are they running 24/7?
    Also, get your passkey sorted as it gives you access to the Quick Return Bonus scheme - just go to the passcode link and enter your e-mail address - if it is the same address as you used previously, they will re-send you your pass code.
  7. GeorgeStorm
    16 Dec 2008
    The RTX is yeah, turned off every now and again for short periods if I need to do some testing and need to free up the core.
    Got the passcode sorted and now fahcontrol says 2m+ ppd for the RTX, hasn't changed for the 980, in fact at the moment it's saying 50k. But not as bothered about that one, as it's my daily pc so more likely to be playing video, maybe a game so turning it off and on etc, and isn't on 24/7.
    Edit:
    Looks like that's definitely woken it up :)
  8. DocJonz
    24 Apr 2009
    That looks like it is going in the right direction ...
    I think the QRB will kick-in fully again after completing your next 10 work units (see QRB qualification link)
  9. GeorgeStorm
    16 Dec 2008
  10. clanseven
    clanseven What's a Dremel?
    11 Jun 2014
    Hi George. I have an RTX 2080ti and it does around 2M PPD. Yours should definitely lift the team a bit!
