Right. Had Vamp fix, and new software has been installed. I like it. The keyboard is nice to use, and I'm now i'm getting use to the mouse, it seems accurate enough for me - and due to that I'm guessing that it'll be accurate enough for the majority of people. The Internet hotkeys are simple to configure - You can type in a hurl in the setup window, or navigate to a page in explorer and set it by pressing CTRL and the iKey you want. The manual says it will work with Winamp 2.X, but I've only got it to work with it once 'amp has been started. All the other AV software it detects show up on a menu when you hit the 'media' key, and will start up if it's not already running, but not winamp.... I'll have to browse the help and figure that one out. Unloaded - I'll experiment (Bwuhhahhahhahhah!) with distance tommorow when I've got a bit more time. TTFN AF
Very very soon Don't buy one until you read it! BTW I fitted a LED inside the receiver but since I have it mounted underneath the desk you can't see it! Oh and don't try and change the red led in the mouse it just won't work
