Build Advice New Upgrade from Q6600 to i5 2500k
Discussion in 'Hardware' started by Groovedude, 14 Jan 2013.
  1. Groovedude
    Groovedude Member
    29 Aug 2003
    Hey all,
    i need some advise i've been on Q6600 for a while and finally have purchased some new parts. he is what i have so far.
    Corsair 650W TX Series PSU - 120mm Fan, 80+% Efficiency, Single +12V Rail
    Corsair Hydro Series H60 High Performance Liquid CPU Cooler
    Intel I5 2500k
    Gigabyte Z68AP-D3 REV2.0
    Geil Enhance Cobra 1333Mhz CL 9-9-9-24 (2 x4GB) *GEC38GB1333C9DC*
    OCZ Vertex 4 SSD *OS-DRIVE* *64GB*
    Corsair Force 3 SSD *Programs & Games* *60GB*
    Western Digital Blue *temp/dump ground for random files* *500GB*
    Pioneer DVD-RW DVR-219L
    Asus Xonar DX
    XFX AMD Radeon 6870
    My main concern is would the H60 cooler be enough to keep a decent overclock on the i5 or do i need a higher model, should i be looking at getting a faster set of ram or even going to 16gb?
  2. mrbungle
    20 Sep 2004
    That cooler should be good for 4.5ghz or there abouts.
    Depends on the chip and how quickly it starts to need volts.
    Mine can hold it o pretty much stock volts, others need a bit pumped through them.
    Ram is ok but I would get a 1600mhz set, 8GB is fine for a gaming system.
  3. Groovedude
    Groovedude Member
    29 Aug 2003
    that's good to know..
    so if i got something like:
    Corsair 8GB DDR3 1600Mhz Red Vengeance Memory
    - 2 x 4GB Kit
    - PC3-12800
    - CL9 (9-9-9-24) 1.5v
    that would be good enough ram?
  4. mrbungle
    20 Sep 2004
    That ram is perfect, especially if you like red things :baby:
  5. Groovedude
    Groovedude Member
    29 Aug 2003
    i don't understand why but seems to be cheaper than the black and blue, people dont like red? .... :D
  6. mrbungle
    20 Sep 2004
    The white looks good on Gigabyte boards but its hard to get hold of.
    Failing that id get the cheapest :)
  7. Groovedude
    Groovedude Member
    29 Aug 2003
    don't tell me things like thaat... haha!
    i got myself:
    Corsair Memory Vengeance Red 8GB DDR3 1600 MHz CAS 9 XMP Dual Channel Desktop Sandybridge
    120mm Corsair Air Series SP120 High Performance Edition, High Pressure, 2350rpm, 62.74CFM, 35dB, 3-Pin, Twin Pack
    boost some power on the H60 as its just got single fan that came with it a while back.
  8. sniperdude
    sniperdude Active Member
    8 Sep 2010
    The white Corsair Vengeance is also low voltage 1.35V
    scan has it
  9. Groovedude
    Groovedude Member
    29 Aug 2003
  10. mrbungle
    20 Sep 2004
    You don't really need LP if you have a H60 either.
    Handy for big air coolers though.
    GL with the build, should clock easy and be a big jump from the 775 stuff.
  11. Groovedude
    Groovedude Member
    29 Aug 2003
    Thanks i shall put most of it together tonight. and await the ram. Hopefully come tomorow.
  12. Guest-23315
    Guest-23315 Guest
    Yeah, I've got the LP stuff in black, and there is still barely enough clearance to get my AC i30 on there..
  13. rollo
    rollo Well-Known Member
    16 May 2008
    The best fans for the H60 are the stock fans it comes with acording to anandtechs testing may want to test with its basic fans before paying extra for new ones.
    If you get a nice chip h60 will carry the 2500k to 5ghz np if you get a bad chip you may not hit 4.4ghz thats kind of overclocking for ya.
  14. bodkin
    bodkin Overheating
    8 Apr 2009
    I would get a bigger SSD. Go for a slower one if you have to for price, you will fill a 64gb one way to quickly with just a couple of games
  15. Groovedude
    Groovedude Member
    29 Aug 2003
    yeah i was thinking that but i tend to only play one pc game at a time on pc.. once complete Uninstalled. i tend to do all my multiplayer / repeat gaming on ps3.
  16. yougotkicked
    yougotkicked A.K.A. YGKtech
    3 Jan 2010
    you might want to consider keeping windows on the HDD and leaving all 64 gigs of your SSD free for games and applications: windows might take a while to boot up, but it only needs to boot once a day usually. try it out, see how fast it boots, then decide if it's worth the 30-odd gigs of space it takes up on your SSD.
    Anyone know who sells corsair their parts usually? those low-profile dims make me think they are re-packaging samsungs 30nm parts, which overclock like you wouldn't believe (I never maxed mine out, since I cant use a divider above 2133).
    I made the same exact upgrade a while back, dumping my q6600 for the 2500k, really happy with the performance boost.
    Don't sweat the cooling, I'm using a air cooler that's at least 7 years old now, and I was able to bring my chip to 5.2Ghz, held the boards highest geekbench score with a i5 for while. any form of liquid cooling will do just fine.
  17. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    I would have thought that for general day-to-day usage, you'd want Windows on your fastest drive, i.e. the SSD. Otherwise, the only benefit you'll get from the SSD is faster loading times on your games, but you'll not see the benefit of the SSD for anything else.
    Also, I'm not sure what the obsession is with boot times :D The benefits of an SSD are far greater than just faster booting - they make using your computer (after it boots :)) far smoother and quicker.
  18. Elton
    23 Jan 2009
    Just make sure that your downloads and documents folder is in another drive. Saves space. ;)
  19. Groovedude
    Groovedude Member
    29 Aug 2003
    i got two SSD..
    the Vertrex is my Os drive with like office etc installed. have 27GB free.
    and then the Corsair is my data drive for games and other software.
  20. yougotkicked
    3 Jan 2010
    ah, glossed over the second one, with ~120 gigs of flash memory there's no reason not to keep windows there.
    @bawjaws: because of caching, once something is loaded into memory there *shouldn't* be much of a performance difference between an SSD and a HDD, as the data is stored in RAM by the time it is accessed. This isn't always the case, but on the whole a SSD outshines a hard disk during boot-up and loading programs much more so than in random daily usage.
