Displays NEWB QUESTION! HELPPPP
Discussion in 'Hardware' started by wdC`, 1 Aug 2007.
  1. wdC`
    wdC` New Member
    1 Aug 2007
    Hey guys i need a quick question answered
    Ive got a 20inch benq lcd widescreen that i use as my primary computing screen, ive also got a 42inch samsung lcd TV that i dual with my computer for watching movies on laying in bed!
    I wanted to sell both screens and get a 32inch or 26inch LCD samsung TV, that i could use for everything, (TV,XBOX GAMING, COMPUTING).
    the resolution on the 32inch and 26 is 1366 x 768
    But ive been told by people it will be ****! so i was thinking of getting another benq 20inch widescreen the exact same model.
    2 x 20inch dual setup for computing and one big 42inch lcd for watching movies?
    which way should i go?
    thanks all!!!!:duh: BTW ITS A BENQ FP202W with 8ms RESPONSE
  2. Guest-16
    Guest-16 Guest
    Welcome! :)
    The Samsung 32" TV will be naff. The Dell/Samsung 30" monitor with a 2560x1600 resolution is sold as a computer monitor for a reason ;)
    You will need a second graphics card to output to the 42" TV if you want another monitor. It depends what you do on your PC though: gaming is better on one monitor because your crosshair will be centre screen unless you play supreme-commander which supports 2 displays. Two monitors are easier to divide work/windows between, but it depends how you use a PC. I can't live without two now, personally.
    Ideally? I'd say 42" 1080p plasma and another 20" :D
