Modding Newbie doubts (from Spain)
Discussion in 'Modding' started by el_mago8, 30 May 2004.
  1. el_mago8
    el_mago8 What's a Dremel?
    25 May 2004
    Hello to you all!
    I am about to start my first mod, and after reading and searching tons of guides, a few doubts bumped into my mind.
    First of all, I want to put a 80mm fan in the front of the case (for which I have to move the power and reset buttons, but thats abother chapter :)), and I am not sure about how to fix the fan to the case.The problem is that the front panel is a little bit curved so it wont fit completely.How do I do it?
    All suggestions will be good,
    thanks
  2. PsychoI3oy
    PsychoI3oy Minimodder
    13 Apr 2004
    search around the forums for 'fan duct' and see if what you find is something you're looking for. otherwise just cut out a hole and use some long screws with a grille on the front.
  3. indigo_prime
    indigo_prime What's a Dremel?
    29 Oct 2003
    Another thing you could do is use long threaded bolts (about 4mm thick) to thread through from the front of the case. Then you can use washers or spacers to mount the fan away from the curved inside of the case.
