NewQ for 5.1
Discussion in 'Hardware' started by banished, 21 May 2002.
  1. banished
    banished Necromodder
    6 May 2002
    Just in case you were thinking of buying a NewQ and already have a 5.1 card read this email answer I got from their support:
    To: info@newq.com
    Subject: Question
    I am looking at buying a NewQ Platinum for my computer and just had a couple
    of questions. I have a Sound Blaster Audigy Platinum EX, how well does the
    NewQ work with this soundcard? Is there going to be a new product soon for
    use specifically with 5.1 soundcards?
    Answer;
    Yes, it does work with SB Audigy Platinum EX card however installing NewQ
    Platinum to your PC will not greatly enhance sound quality since NewQ
    Platinum only supports up to 4.1 channel speaker system.
    Yes, we will be launching 5.1 channel model in very near future.
    This model will be a combination of FM tuner, DVD player with 5.1 channel
    SRS Equalizer system.
    But, if you do have a 4.1 or less sound card, everyone I've ever seen that reviewed them said that it was a great product that gives great sound for these systems (plus they look really cool in a modded case).
    http://www.newq.com/
  2. x24
    x24 What's a Dremel?
    9 May 2002
    I have one and it's great, especially the FM tuner, which is really a nice feature to have since I don't have a radio. Like they said, it doesn't support digital speakers. If you have two sets of speakers, like I do, then It can give you the surround you want with just any crappy sound card you have. I'm very satisfied with it.
  3. v0id
    v0id What's a Dremel?
    2 Mar 2002
    Ive got the external version and i love it... works like a beaut!!! Plus the remote and FM tuner own - i think im gettin rid of my Aiwa system soon cause of that thing and my new Z560 speakers :D
