News Next Gen OCZ SSD Claims Massive Performance
Discussion in 'Article Discussion' started by Guest-16, 12 Jan 2009.
  1. Guest-16
    Guest-16 Guest
  2. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Sign me up for one.
    Any word on price? Overclockers have the 60gb Vertex 1 pre-order for £207, but cost per gb needs to come down to seriously compete with current hdds.
    edit: just noticed that the 0.5 to 8 range is missing from the graphs. I take it small writes are still slow then.
  3. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I think I just had a little sex-wee.
    Sounds good, though price will be through the roof I'd expect.
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    when is the next SATA standard coming?
    IMHO the best configuration for SSD is to have a drive where almost all it does is to read system files, and have temp folder (eg, the unmoveable AppData in Vista) somwhere on a Raptor together with page files. That way, longer life for SSD, and very fast temp file read/write.
  5. alexandros1313
    alexandros1313 What's a Dremel?
    22 Jan 2007
    It sounds great! Stutter-free gaming at last?
  6. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    ok, so it overloads the standard... will hooking it up to a PCIe RAID controller help?
    Internal quad raid... idk, but that sounds expensive to me! :lol:
  7. bowman
    bowman Minimodder
    7 Apr 2008
    No, not unless it has multiple SATA connectors and allows for the onboard RAID to be done elsewhere.
  8. Teq
    Teq What's a Dremel?
    11 Aug 2008
    You trust anything that comes from Fud? Still if this is true it would be great (assuming pricing was reasonable)
  9. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I could care less about speeds that i can't use unless i use my time machine to buy a future motherboard, right now i'd much rather see the flash ware issue cured. I don't want my SSD that's worth its weight in gold wearing out with 1000 writes.
  10. TomH
    TomH BELTALOWDA!
    28 Nov 2002
  11. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    It's been done, move along. Modern SSDs have MTBFs into the millions of hours (just like your mechanical disk.)
    If you want to know how it's done, then use Google.
  12. naokaji
    naokaji whatever
    8 Dec 2006
    Guys, on another Forum (xs) it was allready posted by a OCZ Employee that it was a Simulation only, not a real drive.
    They do plan to put multiple controllers into one SSD to increase speeds, but the first ones will have two, not four, those with four won't be out soon.
  13. Guest-16
    Guest-16 Guest
    Fair enough :) I was only going on what was reported elsewhere
  14. naokaji
    naokaji whatever
    8 Dec 2006
    No problem, just didn't want people wetting their pants out of excitement:D
  15. Zeus-Nolan
    Zeus-Nolan Minimodder
    2 Feb 2008
    I thought that most ssd's(now) like the intel 32gb and the 80gb last like 72 years if you write 100gb a day to them for 72 years then all of the chips are burnt out? I think i got that from tech report
  16. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    this thing better release at 80Gb for $99 or less.......
  17. wyx087
    wyx087 Multimodder
    15 Aug 2007
    SSD will get my attention when cost per gigabyte is same as a Raptor/VelociRaptor
  18. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    It won't be too long if Sandisk can keep up with this promise. :D
    Probably in time for my next major upgrade! :)
  19. rollo
    rollo Modder
    16 May 2008
    you dream redbeaver
    they are in a league of there own for performance people.
Tags: Add Tags
