Other Next Upgrade
Discussion in 'Hardware' started by meandmymouth, 20 Aug 2010.
  1. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    It's soon to be pay day and I'll have some money set aside (£100 or so) for an upgrade.
    I'm looking for a new hard drive having had some issues with my F1 lately and then I'll have £50 or £60 left over.
    Suggestions?
  2. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    I'd go for a 1TB spinpoint F3 and another 2gb of memory looking at your rig.
    Or save the money and get a 460 next payday!
  3. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Yeah very tempted to save and get a 460, I'm a keen folder too so it's green team all the way.
  4. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    What OS are you running? If it's Vista in particular, I'd suggest the extra couple of gigs of memory.
    But otherwise, what I'd say that what Zinfandel says is bang on :)
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Definitely a 460 next pay day :)
  6. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Running Windows 7, Going to install a 64bit version when I get a new hard drive.
    I am craving a 460
  7. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
  8. rob the bank
    13 Mar 2010
    Or you could move to 4gb if you are running Vista or W7.
    Again RAM is cheap at present.
  9. RadEd
    RadEd What's a Dremel?
    4 Aug 2010
    460 craving. I know how that feels. My 8800GT doesn't number crunch like it used too.
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Much love for the 460 but 4GB of RAM is really the standard.
  11. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Hmm, okay I have a lot to think about.
    Crucial C300 64GB SSD I think to start with, that will be used as a boot drive and for all my uni work and documents, which will free up space on my hard drives.
    Then I'll follow that up with and extra 2GB of RAM (or should I buy a 2x2GB set and sell my current 1x2GB)
    Then the 460 in the near year.
    I think that is a plan
  12. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    For best stability go for matched RAM. If you can't get identical RAM to what you have (another 2 x 1GB), sell what you have and get 2 x 2GB.
    Just my tuppence worth...
  13. sarge
    sarge What's a Dremel?
    23 Aug 2010
    Ram would be the best upgrade imo sell your 2x1GB and buy matched pair 2x2GB
    ram is very cheap at the moment
  14. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Yeah that's what I thought, anyone got a 4GB set to set 800MHz DDR2 or quicker?
  15. Fingers66
    30 Apr 2010
    imersa is selling 8GB of good DDR2 (4x 2GB), you might be able to get him to split: http://forums.bit-tech.net/showthread.php?t=193311.
    Failing that, there are others in the marketplace selling DDR2, not sure of the sizes though, have a browse.
  16. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    I need a few more posts before I can get on the marketplace.
    8GB might be good, I have a lot of CAD and coding to do this year at uni so my PC could spend a lot of time rendering and compiling.
  17. Fingers66
    30 Apr 2010
    Drop imersa a PM, see what you can work out.
  18. meandmymouth
    meandmymouth Modder
    15 Sep 2009
  19. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    2x1TB F3's purchased for £82, not bad eh!
    Next upgrade, RAM!
