Nforce Drivers- What am I doing wrong?
Discussion in 'Hardware' started by modtheplanet, 21 Jan 2004.
  1. modtheplanet
    modtheplanet What's a Dremel?
    10 Oct 2003
    I have recently set up my main rig (hd was dead). I have a A7N8X-Deluxe v2.0 and I downloaded the most recent version of the nForce drivers and now I can only boot up in safe mode!
    While booting the Windows XP Pro screen comes up (with the blue progress bar) then the screen goes blank! I have have tried installing the video drivers before the nForce drivers and its a no go also.
    I was able to install the drivers off the cd that came with my board, they worked. But I am trying to get the most preformance out of my machine as possible.
    Can anyone help me with this? Also is there a nForce destoryer like there is a Detonator Destroyer ?
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    When I installed mine I had no problems.
    I first installed the whole nForce driver pack, then rebooted, I then went to add/remove programs and removed the video drivers, rebooted again and then installed a set of Omega(hacked Detonator) drivers.
    Never had a problem.
  3. mushky
    mushky gimme snails
    24 Mar 2003
    driver cleaner can be useful. Nforce drivers have always been good to me, ive never needed to take old ones off before replacing with newer ones.
    you havent got 2 soundcards in there have you? one onboard + one pci?
