Scratch Build – In Progress NFusion - IgnitiOn Project 19-FEB-2013
Discussion in 'Project Logs' started by NFusion, 21 Dec 2012.
  1. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Nicely thought out and designed. I can't imagine the design work that went in to it. I look forward to the rest of the build. Nicely done!
  2. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    whooaaa, i thoght they were 20mm holes.
    Thats crazy dude :D!
  3. NFusion
    NFusion What's a Dremel?
    14 Dec 2012
    Thank you both.
    Yup, countless hours went into design, but at the end it will be worth it.
    :thumb: yea, 5x 180mm fans all with Magicool radiators for BEASTy cooling.
  4. NFusion
    14 Dec 2012
    Short Update - Radeon HD 7950 Waterblock installation
    EK Full Cover Water Block EK-FC7950 Acetal+EN
    with EK-FC7950 Backplate
    Taking apart 7950 and start cleaning TIM. I used Akasa TIM clean.
    Cleaned GPU and applied thermal pads.
    Applied fresh TIM. I used Arctic Cooling MX-2.
    End result :rock:
  5. Guest-23315
    Guest-23315 Guest
    Thats a nice looking card you've got there :thumb:
  6. KoSoVaR^
    19 Dec 2010
    thats looking awsome :) why not CSQ block?
  7. Guest-23315
    Guest-23315 Guest
    Because CSQ is ugly? :lol::lol:
  8. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    DAMN!! Very nice indeed!! Would love to do a scratch build like this one day, but alas, access to engineering equipment and skill to do this is what I lack.
    Heck, if I were to attempt something like this, I'd probably end up missing a limb afterwards. :p
    Subbed!!
  9. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Oldschool EK blocks = YES!!!
    Also; new case design = YES!!!
  10. NFusion
    14 Dec 2012
    Yes, i think these blocks will look better in this build.
    And the CPU block is also oldschool :D
    Thanks.
    Don't worry you would be fine :thumb:
  11. NFusion
    14 Dec 2012
    Quick update.
    I finally have all of components, so this project will go fast :thumb:
    I installed components and finished tubing.
    Next up is leak testing, hopefully everything will go well :D
  12. Father-Time
    Father-Time Minimodder
    23 Feb 2004
    QFT!
    NFusion, you sir are an extremely talented individual, looks AWESOME, great attention to detail and stunning execution. :rock:
    Looking at it again, and again, and again :) the tubes going through the grill just look somewhat .... out of place i guess, kinda like an after thought, you could go with some bulkhead passthrough fittings just out side the bottom grill, use 45 degrees and you would still retain those luverly curves on the tube :)
    Hope i didnt offend, still looks great either way :)
  13. NFusion
    14 Dec 2012
    Hi Father-Time, thanks for the kind words, it means a alot to me.
    Hmm, i also think bulkhead solution would be better, but i would have to order these fittings, which means waiting for atleast one and a half weeks to finish this build.
    Normally this isn't a problem, but i have a client build that needs my time :thumb:
    No offense taken :D thank you for healthy criticism.
  14. NFusion
    14 Dec 2012
    Hi everyone.
    The Ignition project is on the final stretch. The leak testing went well, so i also did all the wiring, lighting
    and finished project IgnitiOn.
    Thank you everyone for kind words and encouragement.
    Next project is a client build, so stay tuned :rock:
  15. Father-Time
    23 Feb 2004
    Well Done Mate!!
    Looks fantastic, lighting looks really good without being too much, second to last pic, res looks stunning.
  16. Hukkel
    20 Dec 2012
    Looks really nice!
  17. Lehani
    Lehani What's a Dremel?
    27 Jun 2012
    wow really wonderful job you did on thise plastic cuttings and putting the case together, if it was me i rather coose to do something otherwise..
    really great job :) high rated from here... do you make those laser cuttings for others :p?
  18. NFusion
    14 Dec 2012
    Hi Lehani.
    Yes, i also do client builds and i'm seriously thinking about making one "production" case :rock:
  19. panman9
    panman9 What's a Dremel?
    9 Dec 2010
    Loving it so far:thumb:
  20. jamsand
    jamsand Minimodder
    21 May 2011
    looks stunning!
