Modding Nice LED's (Farnell)
Discussion in 'Modding' started by sh3rb, 15 Oct 2002.
  1. sh3rb
    sh3rb What's a Dremel?
    14 Oct 2002
    Starting with blue:
    Surface mount square 5mcd:
    here
    surface mount oval lens 50mcd:
    here
    3mm 45mcd:
    here
    3mm 150mcd:
    here
    3mm 900mcd:
    here
    5mm 100mcd:
    here
    5mm 1000mcd:
    here
    5mm 3000mcd:
    here
    And then we change colour and it gets silly
    10mm Ultrahighbright:
    red max 23000 mcd (yes 23,000mcd)
    here
    yellow max 41400 mcd (yes 41,400mcd)
    here
    and finally
    orange max 41400 mcd (yes 41,400mcd)
    here
    I do requests......... :rock:
  2. japala
    japala What's a Dremel?
    8 Dec 2001
    If you are planning on getting these I suggest that you check that view angle that it suits your needs. 4 degrees is quite narrow.
  3. Cheese
    Cheese Doc
    6 Oct 2001
    Yep very true...
    You can get most colours in 5mm >10,000mcd too (though not the blues obv.)... I've always bought my LED's from farnell :)
    Rob.
    p.s. RS are as good, but you need an account.
  4. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    Ok but a bit expensive - those 3.5CD 488nm ones are very turqoise in colour (pity)
