Modding nice new clear cube at hitechmods
Discussion in 'Modding' started by eddie_dane, 29 May 2002.
  1. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    very nice lighting effect. read more here
  2. Linkitch
    Linkitch What's a Dremel?
    11 May 2002
    :eeek: where is the rest of the PC ???
  3. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    What else do you need?
    • Motherboard top shelf (looks like it's an onboard jobby)
    • Hard disk 2nd shelf
    • CD-ROM 3rd shelf
    • PSU botom shelf
    Meblin
  4. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    I want. With no heat, dual CPU, 1G Ram (or more) and at least 320G of HD :).
  5. v0id
    v0id What's a Dremel?
    2 Mar 2002
    what did u do for the lighting??? looks really good......
  6. eddie_dane
    31 Jan 2002
    I didn't do it. I just posted it for everyone else to enjoy. He use EL glow wire for lighting though...
  7. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    eddie beats me too it :rolleyes:
  8. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    ohhhhh.....pretty!
  9. macroman
    macroman The One
    3 Sep 2001
    That's rather smart looking :)
  10. dakar
    dakar What's a Dremel?
    6 Mar 2002
    I read the article...... the fella stated he cut all the shelve pieces at once on a table saw... I tried it a long while ago..with several different blades on my 10" and 8" table saws.... lets just say it wasn't pretty... even with a panelling blade it still chipped it all up and ultimately just trashed the plexi. A plexi shower describes it best when the blade bound up and the plexi shattered. Only small amounts of the red stuff leaked out my hand.
    Has anyone else tried this and had any success?
  11. eddie_dane
    31 Jan 2002
    I just got a new carbide 60 tooth blade for my table saw and it works good. I have only cut 1/4" stuff though, I am scared to cut thinner stuff since it vibrates so much and cracks (/me remembers experiment with jigsaw). When I was shopping for blades the guy showed me a 80 tooth blade made for cutting plywood and plastic. It wasn't multitasking enough for me to buy but tempted to try it.
  12. Meblin
    5 Mar 2002
    It souldn't be a problem as long a s the work is going like this
    and with a little less feed speed :)
    Meblin
  13. kanuslupus
    10 Mar 2002
    In the article, the writer indicates a 40 tooth blade will work as well. Anyone use a 40 tooth?
    I think I'd go for 60 or better, but then I'd rather buy the correct blade than replace damaged plexi.
  14. dakar
    6 Mar 2002
    I hadn't tried the table saw with 1/4" plexi... only the thinner stuff 0.092" or something like that... I may have been thinking backwards... saving the heavy expensive stuff and experimenting with the thinner cheap stuff... I may have to give it another go...but think i'll grab a new blade on my way home first just to be sure.
  15. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    It is best to use a blade that has teeth which are a little thicker than the blade, also a fine tooth blade running at a medium-high speed and a slighty slower feed rate (don't push too hard against the blade, let it doo the work) would be benificial. It goes without saying that a new, sharp blade should be used.
  16. G8way
    G8way What's a Dremel?
    24 Mar 2002
    Would it be possible to cut plexiglass with a variable speed jigsaw or a hand saw?
  17. dakar
    6 Mar 2002
    Plexi cuts nicely with a jig saw... esp variable speed... Just use the metal cutting blades (i use the 32TPI jobbers) and cut nice and slow supporting the plexi so it doesn't jump around from the vibrations and cause stress cracks.
  18. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    HardOCP was quoting this earlier as the first perspex cube like this
    *Cough Splutter*Linear*cough Splutter*
  19. linear
    linear Minimodder
    5 Oct 2001
    Heh, no worries there, [H] put mine on the front page twice Kyle liked it so much.
    once and again
    Robert (@ HiTechMods) is cool and does good work.
  20. Stu
    Stu What's a Dremel?
    8 May 2002
    Thats well tasty, not as tasty as linears, still tasty nevertheless :D
