Gaming Nintendo Project Café Rumour Analysis
Discussion in 'Article Discussion' started by arcticstoat, 4 May 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. thefriscokid
    thefriscokid why s**t so crazy?
    30 Aug 2005
    June 7th for their E3 conference.
  3. Scroome
    Scroome Modder
    26 Apr 2011
    I wonder if Nintendo will revive their old N64 advertising campaign of saying their console is the fastest, most powerful on earth?
  4. Guinevere
    Guinevere Mega Mom
    8 May 2010
    A 6" screen on a controller would be a bit of a waste if it's "just" a controller.
    It'll be useless for maps, HUD info etc if you have to:
    - stop use the controller
    - look down
    - refocus
    - find your destination on the map
    - look up
    - refocus
    - panic as you've spotted the motion controller has kept moving you while you were checking the map
    - realise you've just been p0wned / fallen of a cliff / crashed / died (Delete as appropriate)
    So what then?
    Maybe handle mini games on it? Like back when dreamcast started the whole craze of embedding displays & mini games in controllers / memory cards:
    Oh wait, it wasn't a craze was it? No, you're right - it was kind of lame.
    So what then? Augmented reality? Have a semi transparent screen for overlays?
    Maybe they'll just do what everyone does with a flat screen these days... install honeycomb on it and call it an iPad 2 killer.
  5. memeroot
    memeroot aged and experianced
    31 Oct 2009
    a slightly better 360 will do fine
  6. NuTech
    NuTech Minimodder
    18 Mar 2002
    There has got to be more to this controller than we've heard so far. I just can't see Nintendo sticking a 6" screen to a dual stick pad then promoting it as the standard controller.
    Current generation controllers are hideously expensive as it is, so what will a touchscreen - and all the electronics that come a long with it - add to the cost (remember, Nintendo doesn't ever lose money on hardware)? How about battery life? Will you now have to remember to put it back on charge after every time you finish playing with it? Or will it be wired (highly doubtful)? How big will it be and how much will it weigh? Will children struggle to use it?
    If this controller does come to fruition, I suspect it will be an optional accessory similar to the Wii Balance Board. But doesn't it then risk splitting the install base, leading to only a handful of first-party titles supporting it?
  7. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    This was a pretty good article. Thinking of the graphics processors in consoles in the same way as in PC's is a little deceptive though. For example, even though the 360 chip is based in DX9, it has the ability to do tessellation. Also, while the PS3 gpu is only geforce 7, correct utilisation of the cell processor allows different graphical effects as well. Of course the articles overall point is correct however, that a DX10 based GPU will help PC out too. Though at this stage of the console life cycle I'm not sure the PC needs any help as devs commit more resources to having great screenshots based on PC graphics to sell 360 copies.
  8. arcticstoat
    19 May 2004
    Well, it's all rumour at the moment, so it may not even exist. However, I'd imagine that it's not that hard or expensive to make a touchscreen controller now. The Nintendo DS had a touchscreen controller, as well as a standard screen and all the console electronics for £99 when it launched in early 2005 - I'd wager that making a controller with just a touchscreen and some buttons won't be significantly more expensive than the Wiimote and Nun-chuck combo was in 2006, particularly if Nintendo only bundles one in the box. Small-medium sized touchscreens are now mass-produced on a large scale for all sorts of devices - GPS, tablets, POS, cash machines - it's not infeasible that Nintendo could put one in an affordable controller now. Power-wise, I'd imagine it'll come with a rechargeable battery - if people are happy to recharge their smartphones every other day, then it's not a huge leap to imagine they could do the same with their console controller.
    The controller is probably going to be a key factor here - Nintendo needs to produce something that distinguishes itself from the competition and has more wow factor than the Xbox 360 and PS3 - the specs alone aren't likely to do that (as with the GameCube) - a flashy touchscreen controller could be just what Nintendo needs to get the wow factor.
  9. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    What have you got against two pints of lager and a packet of crisps?
  10. arcticstoat
    19 May 2004
    It's one of the worst programmes that's ever been made, that's what.
  11. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    What? Have you tried using games that utilise the touch screen as a d-pad on the ipad? I've been playing speedball two evolution which uses that kind of controls and they are awful. You have no tactile feedback and it's inferior to thumb sticks or the good old fashioned d-pad.
  12. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    AMD (ATI) managed fine with the HD48xx mobility line (literally downclocked versions of their desktop counterparts) so in theory a full 800sp model is do-able from a thermal point of view although cost could be an issue.
  13. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    I would love that the GPU would be a DX11 type... If everyone goes for DX10 in their next console iteration, then we are dooomed... dooomed.....
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    The biggest success-factor for consoles isn't the hardware and it never really was. The reason why consoles are successful is, that they're as easy to use as a DVD-player: put in the disc and start playing.
    There's especially two areas, where consoles are far superior to PCs and that's sports and arcade-titles and these are exactly the titles, that are the most successful.
    Now, especially the arcade-titles do not really depend on most advanced graphics, but on gameplay and the sports-titles don't depend on large levels or huge drawing-distances lowering the requirements for processing-power aswell.
    The gameplay got alot more fun during the last two or three years with the introduction of the several motion-control-systems and tbh, especially the partygames don't really need fancy graphics.
    The tech-savvy people on tech-forums really need to approach these topics from another POV sometimes to understand the success of consoles like the Wii.
    So, if the new Nintendo-console can combine the graphics of the Xbox360/PS3 with the gameplay-experience of their successful arcade and sport-titles then it'll be a huge success allready for the next years to come.
    I'm more into MMORPGs, so I'm not too much interested in consoles, as there's not that much MMOs available for consoles, but if all the new MMOs would be available for consoles (SWTOR, TERA, TSW, etc) then I wouldn't need my PC for playing games anymore at all. And yes, you can use USB/Bluetooth mouse and keyboards with consoles, if the usual controllers aren't your thing. And think about playing TERA with a motion-controller... that'd be awesome imho.
    So, consoles still have alot of potential imho, even if they don't offer the best graphics.
  15. arcticstoat
    19 May 2004
    Maybe I didn't make this clear enough, but my thought was that it wouldn't replace the D-pad for the exact reasons you mention; it would work as a mouse-like controller in addition to the D-pad - for controlling things like POV in a first person shooter, much like the controls on the DS. This would be much more precise than a Wiimote or a second thumbstick when it comes to controlling your POV.
  16. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    The only place for touch screens is the job centre or the dump.
  17. Guinevere
    Guinevere Mega Mom
    8 May 2010
    But have you ever tried it? I've played many a game on my iPhone and iPad and when it comes to touch screens emulating a standard control configuration all titles have one thing in common.
    The controls suck!
    Now come at it from a different direction, and a big touch screen is fab. There's something wonderful about playing multi touch compatible world of goo HD with my 4yo twins where I'm frantically trying to stop the damn tower from toppling over and they're not. You can't get that on any other platforms.
  18. arcticstoat
    19 May 2004
    Yes, I have an Android phone - the controls in games generally suck. I also have a DS, on which the touchscreen controls are generally brilliant, because it's accompanied by a D-Pad and sensibly-placed buttons for gaming - it's a winning combination. I'm not arguing for an all-touchscreen controller here - just saying it makes an ideal mouse-like controller to complement the existing controls.
  19. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Please don't screw this =)
  20. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    I can't see Nintendo dumping the Wiimote, but then why would they need to? It's a bluetooth device run by a software stack paired up with a couple of IR LEDs in a cheap plastic stand. Maintaining support for that is p*ss easy.
    Four Swords on the GBC was brilliantly innovative but hardly played to it's full potential because of the cost of 4 GBA's. Private screen space is something PC gamers take for granted online and during LAN play (screenwatchers must die!) and decent screens mounted on controllers would be brilliant if your competitive game involves keeping secrets from the other players - your moveset in a Pokemon battle game for example - and I think it could actually be better for gaming than motion controls.
    First DS game I played was that launch-title Metroid teaser and having the touchscreen with that lil nubbin thing alongside physical controls made it the most accurate control system I've ever used for a console FPS bar none. Ok, still not up to keyboard + mouse, but the best anyone's come up with to date.
Tags: Add Tags
