Apple Nintendo WiFi Woes
Discussion in 'Software' started by K, 5 Apr 2006.
  1. K
    K 528491
    31 Oct 2001
    I'm having serious difficulties getting my Nintendo DS running online via my connection here in my university halls and was wondering if anyone could help me out. I've exhausted most methods I know of.
    The basic idea is that I wirelessly share the connection from my Powerbook's wifi. This is quite easy to do. You go into Sharing in your System Preferences and select Internet Sharing On. You share the connection from the ethernet and share it to 'Computers using AirPort' and then configure the DS accordingly. Here's the useful site I got a lot of this info from: http://www.macosxhints.com/article.php?story=20051119155606277
    Now, I've done all this on my home connection before (10mbit ntl Cable on a router) and it works flawlessly. Even without setting up a DMZ on the DS's IP. But on this connection at university, I cannot get it to connect to Nintendo's WFC service. It will connect fine to my Powerbook though. I'm guessing because maybe the ports the DS uses are blocked or something? Or because my connection uses a ton of proxies to get online? ie. HTTP, HTTPS, Socks, FTP etc. Would this be a factor?
    So, any ideas?
    I've cross-posted this to the Networking forum too, as it's quite demanding of networking and OS X knowledge, but if a mod doesn't like that feel free to delete one or t'other.
    Many thanks for any help whatsoever.
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    your halls probably allow only port 80 traffic, so, good luck...
  3. fev
    fev Industry Fallout
    13 Aug 2003
    sharing your net connection from halls is against Janet rules... magic eh
  4. K
    K 528491
    31 Oct 2001
    I think you're right about that. The DS uses the following ports to connect to Nintendo WFC: 28910, 29900, 29901 and 29920 as well as 80 (HTTP) and 443 (HTTPS)
    Ugh, there's no magical way around this is there?
    Very helpful. :rolleyes:
  5. fev
    13 Aug 2003
    i'm taking a large dis-like at the moment to people who come on these legit forums asking for ways to get around systems THAT ARE THERE FOR A REASON.
  6. K
    K 528491
    31 Oct 2001
    To play on a Nintendo DS? Please, get over yourself.
  7. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    Your on a UCE campus right? Resnet?
    Should be possible to get through, I’ve got most stuff working (VNC, SMTP Mail, MSN) though the socks 1080 port and HTTP tunnels.
    edit: try programs like proxifier or the mac equivalent
  8. K
    K 528491
    31 Oct 2001
    That's right yeah, UCE. Thanks for the suggestion. I'll have a look for such a program. What halls are you in?
  9. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    Oscott Gardens...they've been alright, bit quiet compared to the coppice, think I’ve seen you about the TIC
  10. K
    K 528491
    31 Oct 2001
    My friend Anna is over there. It's quite nice. I'm at Westbourne Road. It's a bit... Urgh. But the location is great.
    Only been at the TIC in the evenings to see movies at the Imax :p I'm at BIAD all the time.
    I'm guessing something like this might do the trick? http://sustworks.com/site/prod_ipnrx_overview.html
  11. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
  12. Fod
    26 Aug 2004
    get a nice friend to be an HTTP tunnel. no, i have no further info on this, but it's possible.
  13. K
    K 528491
    31 Oct 2001
    You're a star. Many thanks Kevo. I will try it tomorrow when I'm back.
  14. K
    K 528491
    31 Oct 2001
    Ok, this thing seems like it'll do the job... But I have no experience with such things at all. I've only ever used the Terminal once before. Is there anything else that'll do this that is a bit more user-friendly and has a GUI? If not, can you give any advice on how to install it?
