Case Mod - In Progress NitroGlycer by VC
Discussion in 'Project Logs' started by torment lm, 19 Apr 2015.
  1. torment lm
    torment lm Danish Viking
    25 Jan 2013
    NitroGlycer
    Cosmos SE
    NitroGlycer is proudly sponsored by:
    [​IMG]​
    Welcome to my 3rd project
    This is my 3rd project, and the case that will be modified is, the stunning Cosmos SE from Cooler Master.
    This project won't be alike to the others, it won't be super filled with colors and super overrated.
    This time it's going to be more simple, slick and gentle.
    What is the pannel colors then? Black, Grey and White is the planned colors.
    This case have maybe not seen 1.000 of mods but there is quite some fine ones and as well some really spectacular Cosmos II out there.
    So I hope that I can lit up your fire of attension and hope that you will follow the progress of this long term project.
    The timeline is as following.
    Will be finished at the event of CoolerMaster CaseMod World Series 30 April
    To start it all up I've gotten the case to start measuring and tinker with the case.
    here is some photos of the great case that Cooler Master have sponsored
    The Cosmos SE!
    Plan for the hardware
    GPU - Unknown
    MOBO - MSI Z97S SLI Krait Edition
    PSU - Enermax Platimaxx 650W
    SSDs - Kingston HyperX 3K 120GB X2
    RAM - HyperX Fury DDR3 1600MHz 8GB Black/White
    CPU - Intel Core i7-4790K
    CPU Cooler - Be Quiet Dark Rock Pro 3
    Sponsor Items
    HyperX RAM
    be quiet! CPU Cooler
    Prepping for measurement
    Just got the motherboard from the post office and it looks so nice, super simple and beautiful.
    Fits the theme of black and grey perfectly.
    Yet missing 2 RAM blocks but they should be painted and finished within the next few days and will be added!
    I ran out of white paint!
    so I ran out of white paint, which was unlucky i'll have to go buy some more tomorrow, so no RAM or handle painting today :(
    well I decided to take the front panel and remove the first obstacle towards the new front panel :D
    Had to remove the bridge in the middle of the panel, and to do that I had some help from the best friend a modder can have, the dremel!
    And here's the result!
    "Optimus" Prime and Paint!
    So as said before I'm going to paint a few parts and here is some of the progress results!
    For starters I started out with priming the parts, which made them plain mat white,
    and then I applied some more delicate white to them.
    NOTE: Never again going to try and paint RAM, it did not end as I wanted it, so going to buy white RAM instead!
    First Coat. (Bars "Feet" and "Handles")
    After Primed and now applying white! (for more WHITE effect! HAHAA)
    So what do you guys think so far? personally am really excited!
  2. GregEl
    GregEl What's a Dremel?
    24 Jan 2015
    I like it a lot! It looks like a build of a friend of mine. I helped him by designing and 3D printing the covers for the PSU and motherboard IO. I also 3D printed the cable combs for the build.
    Oh and I think you should change the blue LEDs of the Cosmos SE to white ones!
  3. torment lm
    25 Jan 2013
    That's the plan as well, :)
    Yeah the black and white color is so nice to look at, also the MSI krait is a blessing to look at when it's in the case.
  4. torment lm
    25 Jan 2013
    Assembly 1.0
    So assembling the painted parts and starting to look really nice!
    The GPU has also arrived it's going to be a gigabyte windforce card.
    Also the GPU is a little longer than expected so the sidetower is going to be changed slightly.
    The laser parts should be here today as well.
    So for now what do you think?
  5. torment lm
    25 Jan 2013
    Laser parts and GPU
    so the laser cut parts have arrived and I'll be adding them as the case is prepared for it,
    what I was able to put in right away was the side of the PSU shroud.
    as well as the gigabyte g1 gaming GPU, and the last 2 RAM modules came in as well, and it looks fantastic.
    let the photos commence!
    and here's the sidepanel of the shroud
    the last few parts
    Next up is getting the last laser parts added and readied.
  6. torment lm
    25 Jan 2013
    The Rush To The Finish Line
    so the past few days have been hectic, I've not been able to documment all of it, but here is what I've got!
    I had to make some changes to the case to make the panels fit, (design flaw from my side) and as well as that I've "created" the front panel.
    Explanation of the panels!
    The front panl is made of 2 sheets of acrylic, 1 white 1 mat black.
    the white sheet is the one equipped with hole for fans and is the sheet that hold the fans
    the black sheet is cut with a pattern that is representing molecules.
    The side panels is made of 6 sheets, 3 white background sheets, and 3 sheets with patterns on them.
    The overall theme of these patterns is the formula of nitroglycerin, and also give you a hint of the name "NitroGlycer"
    So here's the front!
    First picture is where the front panel is being pressed down, so the silicone is taking it's effect and makes it sit in place.
    Hope you like the project! this is how it's going to be for the competition.
    (I have entered the competetion! http://woobox.com/d7mzqj/vote/for/7256201# )
