A/V No 5.1 for winamp?
Discussion in 'Hardware' started by l'edo, 16 Apr 2004.
  1. l'edo
    l'edo What's a Dremel?
    10 Apr 2004
    hi..
    I own a 5.1 system with 5 Speakers and a subwoofer.... they all work very well in games...
    but I never get winamp to use the rear speakers or the center speaker..
    do I have to change something in the options or do I need a special plugin?
    or is it even impossible to use a 5.1 system with winamp?
  2. kenshin
    kenshin Banned
    22 Feb 2004
    Works fine on mine, well it works for mp3's anyway
  3. planki
    planki ...
    20 Dec 2003
    i never play mp3's in 5.1 on my set up as to me the sound coming out the rear speakers always sounds tinny i would rather stick to stereo for music and crank up the volume :D
  4. quack
    quack Minimodder
    6 Mar 2002
    Go to the options, Output Plugins, open the configuration for Directsound Output. Put a tick in Hardware Acceleration.
    See if that makes a difference. I know it does on my nForce2 mobo.
  5. sonic_87
    sonic_87 What's a Dremel?
    26 Mar 2004
    yup dude tis working wiv 5.1 now must be a default setting in winamp 2x :p
  6. l'edo
    10 Apr 2004
    thx@all
    i did what quak said and it works well now.. thanks a lot!! :thumb:
