No Alt+xxxx key combinations?
Discussion in 'Feedback & Suggestions' started by SteveyG, 16 Jan 2006.
  1. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    I've just noticed that it is no longer possible to bring up special ASCII characters using ASCII codes? It used to be possible, but now you end up doing random things like forum searches or some other odd characters.
    Is there any way to stop this happening?
  2. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    Err, I'm nσ expert, ￾büt it seems to wòrk...
  3. Firehed
    15 Feb 2004
    I noticed that as well. Perhaps it's a Firefox/vB combo thing.
  4. The_Pope
    3 Jul 2003
    You mean use Firefox and it works? I can't imagine why it wouldn't work - afaik it's a fundamental function of Windows...
  5. quack
    quack Minimodder
    6 Mar 2002
    It's the vBulletin Keyboard Shortcuts causing the problem:
    Alt+1 = forum home
    Alt+2 = new posts
    Alt+3 = toggles print view
    Alt+4 = search
    Alt+5 = faq
    Grrr!!!
  6. The_Pope
    3 Jul 2003
    Interesting - I didn't know it could do that! Having said that, surely you hold ALT+more-than-just-one-number in order to get your character eg ALT+129 gives ü
    The vB only causes problems if you let go of the ALT key after just one tap on your Numpad...
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I use &#(code); such as (code)=176 for degree sign °
    I found the 'name' shortcuts like ° stopped working a year or two back, leaving some of my early posts a bit of a mess. :D Bookmark this page. ;)
  8. eek
    eek CAMRA ***.
    23 Jan 2002
    lol, I wonder if anyone has ever considered writing there entire post in ASCII. It would take ages!!
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Save it for getting round RTT's little quirks, ƒtw! :naughty:
    Pope, your example <ALT>129 ü works in Firefox, but <ALT>176 doesn't. May depend on the last digit. :duh:
  10. ajack
    ajack rox
    17 Apr 2003
    It's just VB's access keys. It's designed for accessibility, such that people with disabilities can more easily use the web. It's all outlined in the W3C Web Accessiblity Initiative.
    On the HTML side of things, you just add another option in the <a> tag i.e. <a href="http://www.foo.net" accesskey=1>foo</a> so that when you press alt+1 anywhere on the page, you follow that particular link.
  11. Firehed
    15 Feb 2004
    Not for me. The instant I touch the 1 key with alt held in, it goes off into searchland or something.
    I can't even think to be bothered to do the &#...; approach - in any case, I usually have to experiment to get the right one. I still can't find the right code for the unequal sign ( =/= if you will)
    /edit - meh, damn, missed the quote message checkbox again. It was one of Pope's, I think.
  12. quack
    quack Minimodder
    6 Mar 2002
    Same here, as soon as I hit any of the access keys the page jumps to whatever it means. Most annoying now that I know it does that!
  13. SteveyG
    23 Nov 2002
    Glad it wasn't just me with the problem. I keep losing posts when I try to include the degree symbol!
  14. dom_
    dom_ --->
    4 Jan 2004
    you know the problem here? firefox
    fine in opera ;)
    what do you say to that quack :p
  15. mcshaggy
    mcshaggy What's a Dremel?
    28 Mar 2004
    erm, isnt that a bad thing that it doesnt work in opera? its a web standard, and opera isnt following it ;)
    take that, opera fanboy!
    lol dt880 > hd650
  16. quack
    quack Minimodder
    6 Mar 2002
    This strip says it all. :)
  17. dom_
    dom_ --->
    4 Jan 2004
    hey! dont turn this around!
    big bullies, im telling my mum on you! :p
  18. mcshaggy
    28 Mar 2004
    we have defeated the beast!
  19. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Firehed, why don't you just type != ? Use logical operators :D
    And yet again, a browser war...
    Scorecard:
    Firefox=3,293,409,323 : Opera=2 : IE=-753,273,283,991,329x10^79
  20. ajack
    ajack rox
    17 Apr 2003
    This "problem" should affect all browsers, since it's a web standard. If a browser doesn't support accessibility, it's not a good thing.
