Displays No display on boot up
Discussion in 'Tech Support' started by bazman24, 7 Dec 2009.
  1. bazman24
    bazman24 Member
    29 Sep 2009
    hi when i turn on my pc it boots up as normal but it shows a blank screen on my monitor(no signal) , its a fairly new computer 2 years old have tried a different monitor but still no luck. im thinking it could b the graphics card? need to know if it repairible or jus to buy a whole new computer. has any1 had this problem before or can help?
    thanks
    pc spec
    amd 6400+
    700 w psu
    8800 gtx bfg oc2
    4gb ram
    m2n e sli motherboard
  2. Zener Diode
    Zener Diode User Title
    13 Sep 2009
    Open the case and make sure the graphics card is sitting properly in its slot. Check all connections are secure, including the connections on the monitor. Remove all peripherals (Mouse, keyboard etc.) and then boot. Test the RAM also (Boot with one stick at a time)
  3. bazman24
    bazman24 Member
    29 Sep 2009
    hi thanks for advice will give a try!
  4. bazman24
    bazman24 Member
    29 Sep 2009
    it works! opened up the case took the ram out then put it back and it worked strange!
  5. Zener Diode
    13 Sep 2009
    That's good to hear.
  6. B3CK
    B3CK Member
    14 Jun 2004
    time to run memtest next.
  7. bazman24
    bazman24 Member
    29 Sep 2009
    how do i do a memtest?
  8. Zener Diode
    13 Sep 2009
    As far as I know, you will have to download memory test/diagnostic software, burn it to a disc, and then boot from that disc. I have not used any memory test software so I can't recommend any, but if you Google "freeware memory test software" you might get something (read reviews first).
