Networks No Internet
Discussion in 'Tech Support' started by greshoff, 10 Sep 2015.
  1. greshoff
    greshoff Member
    29 Dec 2004
    I woke up this morning to find that my computer could not access the internet. Worked fine last night. The router is working OK with all correct lights illuminated. THe computer is connected to router via ethernet cable. Tried new cable - no change. Wireless devices can find network and connect. I am mystified as to what has happened overnight while the computer was off. Any ideas on how to trouble shoot this issue. Thanks
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Can wireless devices get internet?
    Run the troubleshooter on the ethernet card on the PC to reset it then if that fails run a winsock fix
  3. greshoff
    greshoff Member
    29 Dec 2004
    THanks. Yes wireless devices can access internet. How do I access the troubleshooter?. The winsock fix is run through CMD?
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Go to your network adapters in control panel & hit diagnose, it'll run some tests, make sure the gateway & DNS are correct (you could always try manually changing the DNS to google as well for a test) then reset the connection.
    Winsock fix is command line but isn't difficult to run
  5. creative
    creative 500rwhp
    23 May 2014
    something conflicting on the IP?
    Try in command: note the space before /.
    PHP:
    ipconfig /release
    ipconfig
    /renew
    see if that works.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    first try cmd prompt ipconfig /flushdns
    winsock fix = Admin cmd prompt, netsh winsock reset
    if that doesn't work, try removing the network card in device manager and scan for changes should re-install it
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Run an ipconfig /all to see if you're getting a correct IP, DNS and DG.
