Cooling no more noisy fans
Discussion in 'Hardware' started by kobaj, 18 Jul 2004.
  1. kobaj
    kobaj Banned
    4 Jul 2004
  2. Jedi
    Jedi What's a Dremel?
    16 May 2004
    these are regularly used especially with watercooling setups, u might want to take note that it works like a heat pump, one side gets nice and cool, the other hot as hell. That heat needs to be removed and that's where fans are required again :p
    also, they are not incredibly efficient are require a fair bit of juice
  3. dom_
    dom_ --->
    4 Jan 2004
    also know as a peltier
  4. Darv
    Darv Bling!!
    12 Aug 2002
    Infact, just to cool down the hot side you would probably need a more powerful fan (louder) on the watercooling than normal watercooling.
    Peltiers are a little pointless IMO. They aren't very efficient and need a lot of cooling.
  5. Skylined
    Skylined Minimodder
    3 May 2003
    Also called TEC.
  6. kobaj
    kobaj Banned
    4 Jul 2004
    did you even read the web page heats or cools by changing direction of curent not changing whitch side its on
  7. chicken george
    chicken george What's a Dremel?
    16 Jul 2004
    dude, this ain't any different from an normal tec/peltier......
    chicken george.......
  8. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
    Ok, yes your right... it does heats or cools dependin on which side its on. You can keep your processor nice and cozey by putting the current in the other way around if you like, but I'd suggest against it.
    Its a peltier! It allows you to "pull" the heat away from the processor, and you then cool the peltier seperatley, since cooling the peltier doesn't affect performance, thus why its used for extreme cooling. Traditionally, a peltier is set up to be cooled by watercooling for "silent cooling"... and its better than having just watercooling on its own (since its being activley cooled by the peltier, not the watercooling).
    A peltier isn't pointless, because it allows you to cool the processor much more than just with standard watercooling, since the heat is actually taken away rather than conducted away as with a normal waterblock/heatsink.
