Windows "No signal" right before login prompt, stays that way
Discussion in 'Software' started by Khensu, 26 Dec 2007.
  1. Khensu
    Khensu likes to touch your special places
    22 Feb 2007
    My laptop with broken screen (was drunk) is connected to an external monitor. However, since this afternoon, the screen has been going blank right before the login prompt. It stays blank, no matter what I do.
    I've tried this on four different monitors, and the same thing happens over and over again. I didn't install any new hardware or software, and I didn't make any system changes. It just "happened" :/
    The problem does not happen in Safe Mode (which I'm using now), though, which seems quite strange.
    Any ideas? Or, anyone flogging a laptop real cheap?
  2. capnPedro
    11 Apr 2007
    It's Windows being switched into single monitor mode (this drove me nuts when swapping ym HTPC between two monitors and a TV during build/install/config). is there a function-esque button on the keyboard which has a picture of a screen/square on it?
  3. Khensu
    22 Feb 2007
    That did the trick. Damn, I feel stupid now :)
    Thanks!
  4. capnPedro
    11 Apr 2007
    No problem. As I say, happened to me too ;)!
  5. iddqd
    iddqd What's a Dremel?
    6 Feb 2006
    What's crazy is how did you post this with a broken screen and no external monitor??
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Maybe with his desktop? ;)
  7. Daniel114
    Daniel114 What's a Dremel?
    9 Sep 2007
    As far as I can tell the second monitor worked in safe mode
  8. kenco_uk
    28 Nov 2003
    I hate drunken screens that break.
