Windows No Sound In IE - Confused
Discussion in 'Tech Support' started by DeathAwaitsU, 24 Jun 2010.
  1. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    I really dont know whats going on here, ive been on engadget and quakelive earlier today and sound was working fine, turned comp off, went shopping, came back, booted up quakelive and now i have absolutly NO sound in IE.
    I can play tracks in winamp just fine, videos in wmp? A-OK, but nothing in IE, if i go to the sound mixer, sound is on and it shows that IE is playing something, but no sound whatsoever comes thru my speakers. I really dont know what could of caused this so anyone any ideas?
    All help appreciated :)
    EDIT: If i disable/reenable ie it doesnt sort the issue either
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    probably be a good idea to reset ie.. then reinstall your plugins like java, flash
  3. J05H11E
    J05H11E Fujitsu Technical Analyst
    5 Aug 2010
    try this... (IE8)
    Internet Explorer > Tools > Internet Options > Advanced Tab
    under the media heading in the settings pane ensure that "play sounds in webpages" is enabled
    Hope this helps :)
