A/V No sound output
Discussion in 'Hardware' started by [KNIGHT], 7 Oct 2012.
  1. [KNIGHT]
    [KNIGHT] What's a Dremel?
    8 Dec 2009
    I am using a desktop computer with an Intel DP45SG motherboard with the built in sound card.
    Since recent times i am experiencing a problem with sounds. The problem is that im not getting a sound output from the line out port. I tried several headphones & speakers but it still did not work. So i tried using the front panel line out port. That does not work too. At time when i shake the jack of the line out cable i can hear a faint sound output. But that is also not constant.
    Therefore i tried re installing drivers, checking sound settings etc.. but i have been unable to fix it.
    Any suggestions?
  2. atanum141
    22 Jul 2004
    Sounds like either the onboard sound is either buggered or the actual port on the audio connection is gone.
    Just pickup a cheapo soundcard on fleabay
  3. [KNIGHT]
    8 Dec 2009
    Is there a way to change the line out from the default port to another port? (ex. set the line in port as the line out port)
  4. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Not completely sure if you can change outputs like that. I've had problems where audio became fuzzy due to the hz being set to a level higher than my speakers could handle.
  5. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    If your on windows 7, right click the audio icon down in the bottom right, select playback devices, and make sure 'speakers' are set as the defualt device (sometimes HDMI or Digital may be accidentially set).
    It's a similar-ish idea in XP, except, you just need to deselect use SPDIF in the advanced audio prompt.
  6. diariodemierda
    diariodemierda What's a Dremel?
    7 Oct 2012
    Download another sound drivers. Thats the problem.
