Other no sound
Discussion in 'Tech Support' started by kingrossi, 28 Aug 2010.
  1. kingrossi
    kingrossi What's a Dremel?
    28 Aug 2010
    hi
    I have no sound can anyone help
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Wow you certainly give alot of info:lol:
    Could you post the specs?
  3. capnPedro
    11 Apr 2007
    Is your soundcard detected in Device Manager?
    Speakers plugged in/switched on?
    Muted in software?
    Hardware mute button?
    Headphones plugged in instead?
    Have you just gone deaf without noticing it?
  4. glendronach
    glendronach What's a Dremel?
    1 May 2009
  5. kingrossi
    28 Aug 2010
    Specs
    Intel dual cpu 1.80 ghz, motherboard: gigabyte ga-p31-ds3l
    video: nvidia geforce 8800 gt, memory: corsair twinx xms2
    Sorry new to this stuff, does this help in any way?
  6. eNcoRe
    eNcoRe What's a Dremel?
    25 Jul 2010
    did u build this pc yr self or or did u now it / what audio drivers do u have
  7. kingrossi
    28 Aug 2010
    Yes I built it my self, it was in custom pc April 08 issue 055
    build your perfect pc for £447
  8. eNcoRe
    25 Jul 2010
    well u might what to make shore that the front audio is pluged on the mobo in and that the audio drivers are install/ working properly
  9. KingSheepy
    KingSheepy ?lemerD a s'tahW
    4 Sep 2010
    Do you use the onboard sound? It's a nightmare in my experience. Drivers suck for onboard imo.
