Build Advice No to X99 and yes to Z170M (Changed thread title)
Discussion in 'Hardware' started by Kronos, 3 May 2016.
  1. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    How are these three items looking guys?
    My basket at Overclockers UK
    Total: £377.93
    (includes shipping: £0.00)
    I suspect the advice will be to go for 2 x 8GB of RAM but I want the four slots filled, (bling) and do not see myself ever needing any more than 16GB of RAM.
    What about adding an Intel 540s 240GB M.2 will this be a reasonable boot drive?
  2. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Might need to change the RAM, its quad channel, Z170 skylake supports dual channel. Fill the slots for sure but you'll need 2 packs of dual channel rather than one pack of quad.
    Unless quad works in dual channel mode, I don't know.
  3. Kronos
    6 Nov 2009
    Thanks for responding I meant to change my thread as I am just going for the two sticks.
    This OK? https://www.overclockers.co.uk/avex...annel-kit-avd4uz124001608g-2ci-my-101-ar.html
  4. SMIFFYDUDE
    22 Apr 2009
    That'll work no problem.
  5. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    Surely there's no difference? It'll just run as dual channel. Quad-channel kits are just four matched DIMMs, and dual-channel kits are two matched DIMMS.
    Only reason to pick and choose between two dual-channel kits and a quad-channel kit would be if it worked out cheaper one way or the other.
  6. SMIFFYDUDE
    22 Apr 2009
    Oh OK I wasn't sure, I thought I'd mention it just in case.
  7. Kronos
    6 Nov 2009
    Will the 2 sticks be any better operationally than four as I was told that with four sticks it would be marginally slower?
  8. jizwizard
    jizwizard Well-Known Member
    24 Dec 2010
    With 2 it will be more stable if your pushing it with the overclock.
  9. Kronos
    6 Nov 2009
    Not really a overclocker Chris, had limited success in the past I have to admit.
  10. Kronos
    6 Nov 2009
    Anyone suggest a decent low profile cooler for this build?
    I am currently using a Silverstone NT06-E would that be suitable?
  11. jizwizard
    24 Dec 2010
    Tbh even when I have filled all the slots it's never caused a problem with my clocks. It's more to do with the really extreme clockers
  12. Kronos
    6 Nov 2009
    Cheers mate, not sure whether to just get two or four, I cannot see me ever needing 32Gb so having the 4 slots filled does make it a little better looking as far as I am concerned.
    Any thoughts on my cooler question?
  13. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    I doubt you will notice any difference in buying 32gb ram over 16, I'd save the money and put it toward something that will make a difference.
    Can you not fit a little closed loop cooler in the case? It's the carbide 240 you are using yeh?
  14. Kronos
    6 Nov 2009
    I did not mean I would buy 32Gb of RAM so I could fill the slots I meant rather than 2 x 8Gb I would get 4 x 4Gb instead.
    I know this is going to sound anal as I do have a closed loop or AIO, the Silverstone Tundra TD03 but I find the radiator to bulky and it spoils the symmetry of the my fan placement and of not forgetting it is also black.
  15. Slizza
    23 Apr 2009
    Still can't see there being any difference other than all the slots being filled.
    Personally i would stick to 2 sticks and maybe later add another 2 if i needed more ram.
    It does increase the risk of faulty ram and instability depending on the board. Some can be temperamental with all the slots full but chances are all would be fine.
    You mentioned that you were not going to be doing much overclocking so pretty much any decent after market cooler will do the job. Just pick one that fits the style/price point you like.
    EDIT: Also do pay attention to the height of the cooler and ram. especially on smaller boards air coolers can block the first ram slot and deem it unusable while the cooler is installed.
